Question about Whynter SNO 13000 BTU Portable Air Conditioner
Whynter sno model arc-13W/S stopped working
Everything was fine for about 4 hours, then it just quit, display lights are still on. I reset the breaker, which was fine, but that didn't help.
4 Suggested Answers
icemelts
  • 246 Answers
SOURCE: whynter 13000 sno no power
Could be a lot of things - but I'm wondering if when you are checking the 'fuse at the plug-in,' are you actually checking the outlet for voltage?
I would check the outlet for voltage; i.e. plug in a hair dryer or something to the outlet and see if it (hair dryer) comes on. If it doesn't then I would check your breakers and see if you have a breaker tripped. In homes - you can usually go to your breaker panel (usually in the garage or a store room, i.e. pantry, hot water closet, sometimes in hallways behind doors) and find the breaker panel.
On a small unit like yours it would probably be a 15 or 20 amp single throw (like a light switch) breaker. If it's 'tripped' it can be in a position that resembles half on and half off, or it can look completely 'off.'
Remember - if it's a 'tripped breaker' - just re-setting the breaker might not solve the problem. There is usually a reason for a breaker tripping - although they do on occasion 'trip' for no reason.
In any event - if it's a tripped breaker - i would reset it and then if it happened again, either within a few minutes/or an hour - or within a day or two - then I would suspect something wrong with the unit and I would need more information, or you might need a qualified technician to trouble shoot the unit.
Note: if the breaker is tripped and when you reset it - it immediately 'pops back off.' Leave it off and call a tech - because you have a direct short and it will have to be trouble shooted.
good luck!
Posted on May 03, 2010
SOURCE: the arc-13w/s was working fine for about 4 hours
Ours just did the same thing 6/28/2010. And then it wouldn't turn back on. Try draining the water tank. Plug is on the back at the bottom. Ours is running again!! I'd jiggled and sloshed the unit and it came back on briefly. After we drained it, it stayed on. FYI: We rolled our unit over to the top of the stairs so we could get a container under it without having to pick up the unit. Much luck to you!!
Posted on Jun 28, 2010
  • 4736 Answers
SOURCE: Brand new Whynter ARC 12
Check the positioning of the water bucket It may be slightly out of place and is not triggering the switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit for 12 - 15 minutes. Then plug it back in and turn the Master Switch ON/OFF Switch to ON. Set the controls and it may have reset itself.
If none of the above soled the problem contact the manufacture's Customer Support or Tech Service Dept.
Hope this helped you to solve the problem. Please let me know. Thanks.
Posted on May 05, 2011
Control panel lights on whynter 12000 btu portable air conditioner .can't read some numbers
This is due to the detrioting condition of the display, sometimes an even lite press with fingers on the display may help. This happens due to loss of contacts inside due to poor quality of display or aging.
Oct 13, 2015 | Whynter ARC-12S ECO-FRIENDLY 12000 BTU...
I HAVE A FEDDERS AIR CONDITIONER MODEL AED24E7F-C THIS UNIT TRIPS THE RESET BUTTON ONCE IN A GREAT WHILE IT RUNS FOR HOURS OR DAYS ON END AND THEN TRIPS. IT TAKE AWHILE AFTER THAT BEFORE I CAN RESET...
The reset button is part of the cord. The cord has built in arc detection. This is a complex circuit that monitors the unit and senses potentially dangerous sparks or arcing inside the internal components of the A/C (motors, switches, etc.) It sounds like the problem is getting worse - as they usually do. Sparking and arcing happen when dirt, corrosion, etc. accumulates and can result in pitted contacts. All of these conditions only make the sparks and arcs worse. Page 1 of the manual (left column) says this:
If the Arc Detection Device has tripped, the
reset button will pop up.
Follow these steps to reset the Arc Detection
Device:
1. Unplug unit from electrical outlet
2. Press the reset button
3. Plug the unit back into electrical outlet
4. Check to see if power has returned to the unit
Testing
You should test the Arc Detection Device
equipped power cord monthly, after every major
electrical storm, or if power to your Room Air
Conditioner has been interrupted.
Follow these steps to test the Arc Detection
Device:
4. Press test button. Unit should trip and reset
button will pop up.
5. Press reset button again for use
If above test fails, stop using the air
conditioner and contact customer service by
calling the following toll-free number:
1-800-332-6658 or email:
customerservice@fedders.com
I hope this helps & good luck!
Aug 30, 2011 | Heating & Cooling
Hello - I am trying to find a replacement part for a SNO portable ice maker - it is the rotating plastic plate that collects the ice as it comes off of the freezing nubs then pivots and dumps the ice into...
Hi Scott and welcome to FixYa, I am Kelly.
Your talking about either the T-1A or the T-2M portable ice makers by Whynter. The only think I can recommend is that you contact them directly here:
Phone: 866-WHYNTER Email:info@whynter.com
or use this link to use an on line contact form:
http://www.whynter.com/contact_us
I do not know of any external sources for the part you need.
Their ice maker products are here:
http://www.whynter.com/product/refrigeration/ice_makers
This information is from their product guide:
To obtain service or information, contact
Whynter Innovations Group via Email at service@whynter.com or call 866-WHYNTER
Thanks for choosing FixYa,
Kelly
Jun 12, 2011 | Vacuums
Brand new Whynter ARC 12 SD, just plugged in and red warning light about power button is blinking. Booklet says the light will blink when water reservoir needs to be emptied. But, it's brand new, no...
May 05, 2011 | Whynter Portable Air Conditioner
The arc-13w/s was working fine for about 4 hours or so, and then it just stopped working. now it seems like there's no electricity going into the system at all.
Jun 26, 2010 | Whynter SNO 13000 BTU Portable Air...
Whynter 13000 sno no power
good luck!
May 02, 2010 | Whynter SNO 13000 BTU Portable Air...
Whynter SNO 13000 BTU Portable Air Conditioner Logo
83 people viewed this question
Top Whynter Heating & Cooling Experts
Oloyede Monsuru
Mohamed Ismail
Mohamed Ismail
gbob59
Are you a Whynter Heating and Cooling Expert? Answer questions, earn points and help others
