Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
Dryer is spinning but the burner wont fire up
Dryer is approximately 5 years old has always worked fine and just stopped drying. After troubleshooting it was determined that the burner is not firing up.
  • goggomobil Jul 07, 2010
    Check your igniter (look for the glowing element). If that comes on and then shuts off, the gas secondary valve coil is suspect. If the ignitor doesn't glow, check it with an ohmmeter (should read zero) with the dryer UNPLUGGED. If it reads high, the ignitor is bad. Other suspect items would be the high limit sensor (in the combustion chamber) timer, radiant sensor (in the combustion chamber).
  • GE Master
  • 43,501 Answers
Hi, If you have a gas dryerdryer is spinning but the burner wont fire up - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2dryer is spinning but the burner wont fire up - 2_bing.gif class= is electric2_bing.gif..
Thdryer is spinning but the burner wont fire up - 2_bing.gifbe a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jul 11, 2010
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Seems to work but doesnt dry
check the entire exhaust vent wok
a moister sensor detects any built up of lint and shuts the burner off to prevent fires starting
Jun 09, 2010 | LG DLG5932W Gas Dryer
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
The cooktop igniter wont stop firing even when turned off
one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad.
Jan 13, 2010 | Cooktops
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
Drying on-and-off
I would replace the coils on the burner valve assy.
Mar 17, 2009 | Whirlpool Dryers
Siemens Wash & Dry 6140 (Front loader Washer drier)
SUCCESS !!!! - WOT A RESULT.! - SO PLEASED I HAD A GO.
Dry joint found on PCB was BLACK & MELTED, specifically one on the relay terminals was not connecting to the pcb track anymore ;looked like poor original solder joint.
GOT THE OLD SOLDERING IRON OUT, FLUX PEN AND SOLDER AND VOILA!!!
SAVED £280+ (SIEMENS QUOTE: NEW PCB £200 PLUS LABOUR £40/HR)
Mar 24, 2008 | Washing Machines
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
129 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
