Question about Konica Minolta magicolor 2300DL Laser Printer
I have a streak from top to bottom of page that is about a 16th of an inch wide that does not print. What part needs replaced and where do I purchase it?
    Problem Solver:
  • 18 Answers
Sounds like a printer head problem. Take it to a shop where they normally refill printer cartridge inks, and get them to service your printer head.
Posted on Jul 07, 2010
I am having some very large, consistent streaks that just run across some of the top of my pages. If I print or copy out 20 pages only three or four will have this streak. It looks more like a stamping...
Sounds as though the fixing film assembly ( FM2-1793-020 ) in the fuser has developed a build up of toner causing what is normally called offset. You may also have to replace the lower pressure roller ( FC5-7207-010 ) also. You will have to remove the right side covers, door, and then the fuser assembly. Rebuilding the fuser has some challenges until you've done it a couple of times. Good Luck.
Jun 09, 2011 | Canon imageRUNNER 4570 Copier
2130cn printer vertical light streak about 1/2 inch wide down the paper from top to the bottom of the page. using non-dell toner BD
Hello.
The most common reason is the toner. Replace the toner with another. Use a Dell toner, if possible.
Hope this helps.
Oct 19, 2010 | Dell 2130cn Laser Printer
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Copy is smearing from top to bottom on left side of paper about 1 inch wide.
The print in the smudged area, does it wipe off the page like not fused well to the paper. Do you also have a crinkling noise, if so the sleeve in the fixing assembly has torn. You may still have it under warranty with canon and can get it fixed for free.
Good luck
Bob
Apr 23, 2009 | Canon imageCLASS D320 Digital Copier
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
106 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
