Question about Cameras
Hi. Help for a 'dummy' just purchases a new technica pro digi camera and i the book refers to 'formatting' my 4gb sdhc card. How do i do this? Many thanks anticipating your help
  • 477 Answers
You only have to format the card if it needs it if you do hit the menu button the find the setup tab scroll down to format it might ask you internal or card select card it will tell you that formatting the card will erase all photos on it if none are on there that you care about than proceed with the format.hope this helps
Posted on Apr 18, 2008
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
I purchased a new memory card for vacation. When
Is it an SDHC card of 4gb or more? If so, check to see if your camera can handle cards that large.
Jun 10, 2010 | Kodak EasyShare CX7430 Digital Camera
How can you format a SD 4gb card for the Kodak EasyShare Z612 Digi Camera
You can't. The Z612 uses SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card and is incompatible with SD devices.
For SD cards (2GB and smaller), you'll find the Format operation in the Setup menu. Press the Menu button, then use up/down to select the wrench, then press OK.
May 13, 2010 | Kodak EasyShare Z612 Digital Camera
Problems with formatting memory card
I'm guessing you're trying to format a new 4GB SDHC card? If so, am sorry to say that your camera was designed before the SDHC format came out. Although it looks exactly the same as a standard SD card, the format the card uses is very different.
You'll need to instead purchase a standard SD card (those that are 2GB or less). Forunately these are very inexpensive these days, with 2GB cards going for around $6 with shipping.
But if you must use 4GB, Transcend makes a 4GB standard SD card, but I can't guarantee that it will work with your camera as anything above 2GB for standard SD may have compliance issues.
Nov 02, 2009 | Cameras
Same as yours
The Z740 supports only MultiMediaCards & SD Memory Cards. 4GB and larger SD cards are usually SDHC (Secure Digital High Capacity) types - and bear the SDHC mark on the label. These cards are not compatible with this camera. Use only MMC and SD cards. SD cards are 2 GB and under - although *some* 4 GB cards are marked as SD too; these cards may or may not work. If you purchase a 4 GB SD (not SDHC) card, make sure that it can be returned if it doesn't work reliably in your camera.
Oct 05, 2009 | Kodak EasyShare Z740 Digital Camera
What memory card do you use for vivitar vivicam 4100? i tried putting in a 4gb sd card, and then the camera wouldnt load up with it in.
The new 4GB card is likely an SDHC card (see if SDHC is printed on the card). Although it looks the exact same as a standard SD card, its file format is different. Your camera was designed before the SDHC format came out. Unfortunately your camera is not compatible with this card, and there is no way to make it work. Instead consider the wide availability these days of low-cost 2GB standard SD cards. These will work with your camera, and happily only cost about $7 including shipping: http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=sd+card+2GB&x=21&y=22
And hang onto that 4GB SDHC card. It will be compatible with all future cameras that you may purchase.
Jul 19, 2009 | Cameras
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Won't format new memory card
Your camera is not SDHC compatible. It will only support standard SD cards. Sorry.
I hope this helps.
Nov 28, 2008 | Kodak EasyShare C743 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
