Question about Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher
Power light goes on but no water
Our shu6802uc will turn on but no water will go into it. Repairman said it would be cheaper to replace it than repair it. True?
  • Bosch Expert
  • 414 Answers
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
Posted on Jul 07, 2010
My CDA WC430IN slimline integrated dishwasher isn't working. The power comes on but the program buttons aren't working - none of the programe type lights will light up. Have tried switching off and on,...
Try unplugging the cord from the outlet or turning the fuse off from the fuse box that goes to the dishwasher. Wait a few seconds then plug back in to set if it resets itself. Usually if something goes wrong with these types of applicances the whole circut board is replaced by the repair man. Which by the way is cheaper if you can do it yourself.
Sep 20, 2014 | Dishwashers
My dishwasher stays stuck on '1 minute', and will not complete the ccycle or drain the water. I tried to do another cycle on it, and it went to 8 minutes, and then jumped backl to 13 minutes, and repeated...
Make sure that the drain spigot is not blocked under the sink. Water has to pump out OK. Then the most likely fault is the release valve at the bottom of the heat exchanger. It jams because the plunger corrodes. To see to this you will need a competent Bosch technician like me.........after that the electronic might be crook , but I doubt it.
Feb 23, 2011 | Bosch 24 in. SHU6802UC / SHU6806UC...
Power light blinked 4 times and the power to the set never came on. Currently, thats all the set will do;power light blinks and set does not turn on
4 blinks is a vertical Stoppage, this is a failure on the D board. There are many ways to approach this repair. The easiest self help method is to replace the D board. (On some of these sets this board is referred to as the DZ board) But there are hazards when working inside a tv. Care must be taken to avoid electric shock even with the set is unplugged electric shock can still occure. If you are unsure about doing this yourself depending on the approch from the repairman it could cost anywhere from 200 - 350 to repair. I am not in the position to give you the board part number now but if you want it just post back here and i will get it on monday.
Some repairmen will replace the board and some will attempt a component level repair, which is more complex but is usally cheaper for the customer.
Sep 05, 2009 | Sony KP-61V85 61" Rear Projection...
POWER LIGHT FLASHES 3-4 TIMES AND SOUNDS LIKE TRYING TO COME ON B
This will need a capacitor replaced on the power/deflection board. (CP150) This is a very common problem on these sets. Service man will probably charge at least $200
Jul 05, 2009 | Televison & Video
Problems w my mitsubishi hdtv big screen
Typically this is a indication you have a Power Supply problem and not something you can fix with out a repairman unless you have knowledge of the Power supply Circuits in these models . Play it safe. Get a repairman who is authorize by Mitsubishi to look at it.
Hope this Helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WS-55513 55" Rear Projection...
My ps2 when power is applied, the red light turns on briefly and then nothing. Could I have a bad power supply?
Possibly but please do the following:
Tirn console off and disconnet power supply for 30 seconds. then reconnect and turn on the console via the button on the front WATCH THE LIGHT CLOSELY - if it JUST turns on then goes off its either a dead powers supply-perfectly feasable bearing how old the thing is. If it blinks then im afraid your console is dead and a replacement will probably be cheaper than repair. New power supplies can be ordered in by GAME or GAMESTATION if not in stock
Feb 24, 2009 | Sony PlayStation 2 (PS2) Console
Bosch 6802UC dishwasher is leaking water from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Jan 22, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to jah2mil@hotmail.com
Jan 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Bad power supply P/N 313503710471
$495 to repair is good.
The original replacement is $469.75 : 313503710471
Refurbished part is $228.83 : 313503710471
Nov 13, 2008 | Philips 50P8341 50" Rear Projection...
Kenmore 417 front load washer
Normally when the bearing goes, it was most likely caused initially by a damaged water seal that allowed water to reach the bearing. If this has been going on for sometime, then there is also the possibility of the shaft being worn out. Repair or replace decision would have to be done after a visual inspection. Additionally, pls bear in mind that:
  • bearing replacement would require removal of the entire rear half of the tub, less than 100USD;
  • a press would be needed to install the new bearing (if ever available solo);
  • not difficult repair job but very time consuming;
  • often the bearing is available only as part of the whole shell (with spin tub inside) and bearing assembly probably between 150~250USD ?part #134453200? tub ***'y.
Based on all of the above and the result(s) of your visual inspection, then repair or replace could then be made.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 17, 2008 | Kenmore 44042 Front Load Washer
Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
143 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
