Question about LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner
Problem of dvd/cd writter
My cd/dvd writter is not reading any type of cd and dvd when i insert cd or dvd after inserted dvd/cd writter not reading cd and dvd
  • 212 Answers
Check the IDE/SATA cable,if its connected,now u must to become sure from lens.maybe it need to cleaning.therfure,if after cleaning this problem still apear,so u must change the board or somethings in it by testing
Posted on Aug 11, 2010
Eject problem
There is a very small access hole on the front panel - use a paper clip - insert it into the hole and push gently and it should eject.
Feb 12, 2014 | Sony DVP-SR200P DVD Player
I installed cdburnerxp but i cannot burn dvd in my cd burner, cannot detect the dvd inserted, alway said insert writable disk. my unit is Pentium 3, 600mhz, 512ram. it has a cd writter.
your saying that you have only cd writer. how can u write dvd in your system.
If you wrongly posted your problem then check and post clearly
Jun 24, 2010 | Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
When I try to log on it asks me to insert disk F. I don't have a disk F
you can use window media player to play both dvd,vcd and audio disk,clue when you insert adisk into cd writter you can see a msg saying you to allow window player to play the following this , just accept it and it will play or just goto my comuter and you will see a black on the following eritter ready to play and you mrightclick and select play
Jul 10, 2009 | Computers & Internet
Dell Studio 1537 DVD not working
1. clean your cd, then put
2. clean your cd/dvd head
3. scratch cd/dvd shows this type of message
Jun 28, 2009 | Dell Studio 1537 Laptop
DVD drive
turn it of for about two hours the hard drive is probobly too hot =]]
Apr 10, 2008 | Plextor PX-800A DVD Super Multi Drive...
Dvd writter is not working
Replace the rubber belt inside. That rubber belt keeps other rotating parts inside to move faster as the motor is running, replaced it with a tight one so that when your insert a cd the optical inside can easily read your cd. The optical lens need to run with as a desired speed of your ROM xspeed.
Put a new gear belt and replace the old and tired belt inside.
Jan 22, 2008 | LG CRD 8120B (CRD-8120B) Internal DVD...
LG MULTI DUAL DVD WRITTER
your dvd may have power to open up so that you can insert the cd but the only possible thing that i can suggest is that the cable attached to your dvd may be damaged or try checking if your computer recognizes your dvd and if its not recognized... it may have problems on the cable or the hardware itself.
Jan 22, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner Logo
153 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
