1998 Chevrolet C1500 Logo
Posted on Jul 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
98 chevy 1/2 ton. I was driving home and all of
98 chevy 1/2 ton. I was driving home and all of a sudden I had a real stiff brake pedal but very little braking power. I had to use both feet to get stopped at a stop sign.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
218
Points
Abs system on my 1998 chev. 1500 comes on at low speeds on dry roads what is the problem
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Jul 07, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
21057
Points
158
Vacuum booster went bad. the round canister behind the master cylinder. not a real tough job, but if you do not have much brake experience i would advise you to have it done
1helpful
I have a 1987 chevy Cheyenne 1 ton dually w/standard transmission clutch quit working not sure if it be slave cylinder or something else?
Does the pedal go to the floor?? If so it is the master and the slave, they are replace as one unit of repair. If the pedal is very stiff but doesn't go to the floor you have a failed clutch.
Brake pedal goes to floor but you can pump it up on a 98 chevy 1/2 ton could it be something else besides the master cylinder because after its pumped up the pedal will hold steady and not creep to the...
check around the wheels for signs of brake fluid. the most likely cause is the master cylinder.is there anyway air is in system? from repairs made recently? this will cause problem so can try bleeding and if does not cure replace master cylinder
My daughter was driving the 1993 jeep grand cherokee and she stepped on brakes to stop behind car and no brakes. just a few days before i had the brakes checked and they worked good and she had been...
What do you mean no brakes? pedal was stiff would not press down?, pedal went to floor? That needs to be checked. if there are no fluid leaks, I would suspect the master cylinder.
4helpful
2answers
Brake pedal on my 98 chevy s10 is soft
1988 chevy r 3500 1 ton changed out driver front brake caliper
brakes are soft peddle goes to the floor tried to bleed but no brake fluid will come please help
2helpful
2answers
Bleed brakes on 96 chevy 1/2 ton
YOUR TRUCK HAS KELSEY HAYES FOUR WHEEL DRIVE ANTI LOCK BRAKES EBC 310. YOU CAN BLEED BRAKES MANUAL STARTING AT - RR- LR RF- LF. THIS IS BLEEDING SEQUENCE.BUT YOU NEED A TECH 1 OR 2 SCANNER BECAUSE IF YOU REPLACED THE BPVM OR BRAKE PRESSURE MODULATOR VALVE.BECAUSE AIR TRAPPED IN VALVE ASSEMBLY.THE TECH 1 OR 2 SCANNER YOU HAVE PUT IN THE FUNCTIONAL TEST BLEED AIR OUT OF VALVE ASSEMBLY.THEN YOU CAN BLEED BRAKES MANUAL.
The clutch pedal on my '98 chevy silverado is
The clutch in your vehicle is connected to your pedal via a cable system or a hydrolic system. BOTH were available. IF yours is hydrolic, which is doubtful due to behgavior, your cannot adjust it. The cable type is better suited for adjustment. This is done at the end that attaches to the clutchplate at the bracket located on the transmission housing. It will turn to adjust. right tight left lose, it appears that you will need to tighted it a pinch to keep it from "jumping." DO NOT tighten so that the clutchplate disengages, this only a very slight adjustment. good luck
1991 Chevy Transmission won't go into O/D
from what i remember the overdrive is electronically activated. it is disengaged by low rpm or a switch on the brake pedal. check the pedal switch and look to see if there is a disconnected wire near transmission.hope this helps. please rate me
Sudden brake failure
You need to check the fluid in the master cylinder first. if it is empty you have a leak somewhere. if full then probably a bad master cylinder.brakes just being worn will not cause you to lose all pedal. while if they are worn should be replaced if they say you just need a brake job then be suspicous
Replaced clutch but pedal will not move down at all now on 98 chevy 1/2 ton 2wd
Sounds like the release bearing is in backwards! No check valve. If the peddle was pushed, it would pop the slave cylinder piston. 2/ The clutch disc could be in backwards too! Either way, you will need to pull the tranny! Sorry! Frankster016
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
