Question about Kenmore 24032\24036 Top Load Washer
Hot water is filling up washer very slow
It seems like the washer, while using hot water, fills the washer very slow. The cold water fills up quickly.
  • 1 more comment
  • steever1969 Apr 18, 2008
    Thanks for the solution-you were right, the screen was totally clogged, thanks again!
  • kurtz_shelly Oct 04, 2008
    same problem but hot and cold reversed.... my hot runs fine and always has...but the cold has to be cleaned all the time,say about every 3 weeks,we clean it and in no time its almost a trickle again,,,,is there another filter to clean? I'm so confused,,,I have a kenmore heavy duty 70 series, model 110, 82873800. It is about 20 years old, but other than this problem it works great....Can ya help?
  • Anonymous Mar 21, 2014
    When i turn the washer on it does not fill to the correct level and the water comes out really slow. I have to finish filling it with a bucket to get the right water level
  • 145 Answers
There is a screen in the valve where the hose hooks on. It could be getting plugged up. turn off the water and pull off the hose to see if it's full of particles. I can sometimes clean it out by putting a bucket under the water inlet and spaying a little water from the hose into the opening. If not you may need a new valve.
Posted on Apr 18, 2008
  • James Davis Apr 18, 2008
    Glad it fixxed it for you.
Water when filling has slowed down cold water is very slow hot is ok
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jun 26, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
240 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
