Question about Frigidaire GLTF2940ES Front Load Washer
This washer has an error code of DDO, Dispenser door open, would you think a sensor issue or something more?
    President:
  • 1,382 Answers
The meaning for ddo error means"Dispenser Drawer Open" .To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Posted on Jul 07, 2010
DDO have the problem that is the part that I have to change
Thank you for your inquiry, edwin chiu!
Based off the information you have provided your Frigidaire washer is displaying the error code "DDO". "DDO" stands for dispenser door open which could be a problem within your door or reed switch. I would recommend opening and closing you do to secure the connection is proper.
If that does not correct the issue I would perform a reset on your washer which you can do by disconnecting the power from it by either unplugging the power cord or flipping the household circuit breaker for ten minutes. Hopefully this information has been helpful. -Matt
Sep 26, 2014 | Frigidaire Affinity Glacier Blue 3.5 Cu....
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
Display shows ddo error and doesn't start
Thank you !!
Jul 02, 2010 | Frigidaire ATF6000ES Front Load Washer
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
The water wont start filling up - it beeps and then has the code "ddo" on the screen.
Thank you !!
May 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Washer
DDO is dispencer door open
the magnet needs to be put back into the dispencer door the machine thinks the door is open...
let me know
Aug 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
209 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
