Question about Fuji FinePix A900 Digital Camera
Fuji FinePix A900 Digital Zoom error
My Finepix A900 shows me "! Zoom Error" message when i put it on. firstly it was due to batteries discharged before it got closed off, but now it does not work even if i put new batteries. can you help me ?
  • 5 more comments
  • AnahS May 04, 2008
    Mine has done the exact same thing. I put it on self timer and it jammed, the lense wont retract and new batteries havent worked.
  • Anonymous Jun 28, 2008
    Same problem as others,lens wont retract and camera shuts off seconds after it's turnd on?????
  • frankyfriend Jun 28, 2008
    Fuji FinePix A900. Same problem as the others,lens wont retract and it shuts off with in second's after it's turnd on. I dont even get the WARNING!
  • Anonymous Aug 22, 2008
    Zoom error problem, and notify you when a new solution is offered. Camera shuts off after trying to extent lens
  • emytaylor164 Oct 14, 2008
    my a700 is doing the same thing all of a sudden just out of warranty
    so annoying
  • keys11 Nov 08, 2008
    i have exactly the same problem, after only 2 days of me being on holiday ..gutted!!!...ive tried what gaston has posted and it hasnt worked, however mine flashes after 3 seconds and stays blank but then redems the error massage again a few moments later..has anyone else got a suggestion as i use my camera on a daily basis for alot of things?
  • altaran Dec 18, 2008
    tried firmware update without success. zoom error problem.
Same problem with me. Got a zoom error. I thought "it's still under warranty, so Fuji will help me out." WRONG! Fuji repair claims it has impact damage, but that's not true. The product is just defective. Fuji charges $113 to get it repaired. It cost me $140 from Dell only 7 months ago. Defective.
Posted on May 28, 2008
If your fujifilm a900 have the zoom out and wont get back in and that when you push the power botton it light for 3 second and shut off , push the Disp/back and the play ( 2 botton one beside the other) at the same time , it will bring the zom in and tell you to update the firmwere , do that and it will work just like a new camera, Good Luck to all, I have find it out after a few hours of internet search without succes and by error i push those 2 buttons. I found this really funny but it work just fine for me.
Gaston
Posted on Nov 04, 2008
I bought FUJI FINEPIX AX650 6 months ago.Now After taking pics when i press play button to view , it shows READ ERROR.another problem after taking a snap, the LCD display shows blank (color black) for few...
when having a problem with your digital camera. switch it of, remove the battery and charge the battery. When you replace the battery, the error should be gone. If not, you should contact the service centre closest to you.
Jan 22, 2014 | Fuji FinePix AX650 16MP, 5X Optical Zoom...
Zoom Error on FinePix 2800
try resetting the camera by removing the batteries
Jun 24, 2008 | Fuji FinePix 2800 Zoom Digital Camera
My fuji finepix A900 is not charging with usb cable on my computer
The A900 is not a battery charger. It uses two standard AA batteries, either disposables or rechargeables. If you choose to use rechargeables, they must be charged outside the camera, using a separate charger.
Sep 22, 2011 | Fuji FinePix A900 Digital Camera
When I turn camera on it says zoom error! How do I fix the problem?
Try playing with the zoom in and zoom out buttons it usually comes from a a jammed zoom lens.
you also may want to try helping it out.
Mar 02, 2011 | Fuji FinePix A900 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Fuji finepix a900 Frame number full error
Hi!
In case you haven't sorted this out yet.
To fix this go into Menu ---> Setup. From there there's a Frame Number setting. It is normally set to: Continuous. The other option is: Renew which evidently simply resets the picture count. After selecting Renew the error message disappears and the camera works perfectly again.
Great little camera!
M
Mar 17, 2009 | Fuji FinePix J10 Digital Camera
Zoom Error
i have a duji f20 le zoom lens partly out when turn on says zoom error can you solve this please
Feb 22, 2008 | Fuji FinePix F20 Digital Camera
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Fuji FinePix S7000 Digital... Problem: Zoom Error
The manual describes all warnings the camera displays. Check the manual or go here for the manual online in pdf format.
http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf
Dec 13, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix A900 Digital Camera Logo
1,162 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
