Question about Gametime Seattle Sonics Coach Series Watch
Is a manual available for a Sonic B16 Renegade watch? What is the battery type and how to replace battery?
Remove the back, take out the two screws on either side of the CR 2016 coin battery. Replace.
Posted on Apr 09, 2013
What Battery do I use to replace the old one on a Fossil JR1157 Watch?
The owner's manual should say which battery to use. Otherwise, the only way to find out is to open the watch and see what type the old battery was.
Mar 14, 2016 | Fossil Watches
Tip
Finding replacement battery for watch (DIY).
If anyone opted out to replace battery in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help.
on Jan 20, 2010 | Watches
I cant set the date, because I got the battery replaced and I the date is two days late
Use the manual to set the correct time zone, time and date. Manual is available on the Casio worldwide website>support>manual>watches.
Have the module number at hand: you will enter it to find the manual. The module number is a 3 digit or 4 digit number on the back of the watch.
Nov 09, 2013 | Casio G-Shock G 300 G 301B 1ADR Watch
I have a sonic terramax watch and everything work except the arms for time do not move. Anyone have an answer for me
This watch have two batteries. When you open tha back you'll see a big battery mounted on the printed circuit board (PCB). If you unscrew the screws from PCB and take it out, you'll find under it the mechanism with the battery from the analog watch. Replace that battery and "Have a good time"... :-)
Aug 10, 2012 | Watches
Metal pendulum wall clock run by AA batteries... does not run... new batteries do not solve the problem.
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Sep 20, 2011 | Watches
Misplaced my instruction manual - need to reset all after battery replacement - it's been a great watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Most makers advise you to have the battery replaced professonally, so you may not find anything useful in the hand book.
It is usual to shor the battery case to the ac point on the watch using a metal object (e.g. a pair of tweezers), to reset the watch.
Jun 03, 2011 | Timex Expedition 84601 Wristwatch
My watch stopped working. I think I just need to replace the battery in it. how do I get the back of the watch off to do that?
Bulova Accutron watches were originally designed to use Mercury batteries of 1.35 volts, since they were the only type manufactured then. The pic (left) shows an original 214 all-metal "top hat" cell, before 387 cells with the plastic spacer became available. In most areas of the world, mercury-based batteries are no longer available, due to environmental concerns related to the safe disposal of them. The Tuning Fork watches manufactured by Esa (e.g the f300 Omega) were designed to run on either mercury or silver oxide batteries without any adjustment, provided the last repairer to work on the watch set up the index mechanism according to factory specifications.
It is strongly recommended that you do not replace batteries yourself, as special tools are required to open the watch case without damaging it. The only exception to this is the Accutron 214 model, which has a small battery hatch on the back.
Aug 24, 2010 | Bulova 26D08 Accutron Watch
I bought it new and then a few weeks later the battery seemed to stop. I did not wear it often. I heard some watches do not use battery and function with the movement of one's arm. Is this the case for...
If the watch is a self winding type, then it generally says "automatic" on the face. These will run for about 2-3 days if they are not worn, as the self winding action only works when the user is moving).
Battery driven watches should run for at least a year before needing a replacement, so if it has stopped already, it could be self winding or manually wound type. Some self winding watches can be manually wound so you could try this to see if it starts.
Aug 14, 2010 | Watches
End-of-life indicator for Victorinox Night Vision II watch - I seemed to remember that the watch battery can be monitored through the red LED that blinks every 10 secs. when it is OK, if the battery needs...
Not a malfunction - just a dead battery. See the manual:
http://www.victorinox.com/medias/sys_master/timepieces_manuals/8800396705822/NightVision_II_ENGLISH.pdf
May 12, 2010 | Watches
I need a replacement battery for an original navy seal model (3000)? Does anyone know what type and size is in these watches? Other than sending it to luminox has anyone successfully found a replacement?...
If anyone opted out to replace battery2_bing.gif in their own watch and do not know what type and size of battery is correct for replacement, just open your watch case back and reed and memorize all the writings on battery your watch allready has in it. All you can do now is to buy exactly the same replacement battery and you will never get it wrong. All that matters is the combination of letters and numbers on battery. Make is not important, so, it can be made by Casio, Maxell, Citizen, Ronda - you name it. Just make sure you are not buying some of those cheap, unknown maker batteries2_bing.gif, as they usualy lasts for about few weeks and then they are gone. Choose well known makers name and the battery will power your watch for 2-7 years, depending on each particular watch movement model. In case if you lost your original watch battery, check your watch instruction manual. If you lost both - battery and manual - then there is no other way, but to visit your nearest watch repair shop and ask for help. In your particular case I do not see the reason why you should find the battery, because any decent watchmaker has many different batteries in stock. All you have to do is to find your closest watch repair shop and ask watchmaker to replace the battery. No need at all to send it to Luminox, as this job can be done at any watch workshop with the same precision and quality. In addition you will save money for shipping and pay less for battery itself.
Rate me, plz.
Jan 29, 2010 | Navy Seal Luminox Dive Watch
Gametime Seattle Sonics Coach Series Watch Logo
432 people viewed this question
Top Gametime Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Gametime Watch Expert? Answer questions, earn points and help others
