Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Model 34288 robinair . Were is the weight . How do you do A filter change.
  • Hasan Khan Amran
    Hasan Khan Amran Jul 14, 2010
    Please post your Question clearly! it's not clear to me what is the problem?
    President:
  • 180 Answers
There is no Weight in the machine. Machine show Filter weight that you have been recover refrigerant from the vehicles since last filter change! After every 68KG/150LBS of refrigerant recovery you must change the Spin-no filter. The machine ( Model-34788 ) will lock-up when filter capacity reach to 68kg & you will not abel to access the machin till replace new the filter.
When the machine show the filter weight 68kg on screen just press YES key,then add the 10 Digit code of new filter ( Code is stick with evey filter). If the code is accepted then open the old filter & replace new one.Follow the on screen direction to compleat the process.
Note: Do not switch off the machine till compleat the filter change function.
Posted on Jul 15, 2010
  • Hasan Khan Amran
    Hasan Khan Amran Jul 17, 2010
    The machine ( Model-34788 and 34288 ) will lock-up when filter capacity reach to 68kg & you will not abel to access the machin till replace new the filter
Robinair
The amount of oil moving with the gas is minimal as it is only what passes the pistons as lubricant that travels with the gas. The receiver dryer catches most of the oil that is moving. New compressors have the correct amount of oil so if you have the need to add oil check what is in the dryer and that will all that you need to add. If the system has excessive oil in it you will experience problems in the tx valve as the oil blocks up the opening.
May 17, 2013 | Robinair 34288 Cool-Tech R-134A Recovery...
Robinair model 34288 will not stop recovering
what is the pressure reading on your guages? if it is below 0 if so the vacuum pump should kick on. if the vacuum pump keeps turning on and off check the software version on the machine if it is not 3.09 or 3.11 the software needs updated contact your local robinair service center. if it is not the software then the recovery solenoid may be sticking closed and will need replaced.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
34288 scale calibration procedure
the machine came with a calibration check weight in the menue you can check the calibration. if it fails contact your local service center the machines have to be calibrated with certified weights unlike the older machines.
Hi, my robinair ac375 wonot charge gas, gauge up arrow and down arrow wont move, we done filter and vaccum oil and reset. it is possible to get special way to reset gauge?
mhkamran.jpg Please check Charging solenoid (S3) in Solenoid manifold block, it may need to change solenoid coil or Rebuild. If charging solenoid is OK, then problem can be SCALE or MAIN CIRCUIT BOARD. See if the machine display show default charging weight 90 kg/lbs when you active CHARGE mode. If not then calibrate scale. But if default charging weight is shown then replace MAIN CIRCUIT BOARD. See attached picture to find solenoids. I wish this will help you to solve the problem. If so please vote for it for further assistance. Best of luck!
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate scale on Robinair 34134Z
Robinair Model-34700Z scal calibration follow as bellow:
Press main menu then press up or down arrow till scree appear ''CHANGE DEFAULT'' then press 5454 from the keypad & then YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & then press YES key. now follow the on screen text. Once you calibrate scale then press STOP key to exit.
NOTE: You should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE'' or any other setting it must be on factory setup.
Hope this will help you to solve the problem & if my solution is useful to you please vote for it
Apr 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate the scale on a robinair 34700z A/C Machine?
Robinair Model-34700Z,for scal calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE''. it must be on factory setup 16.30 lbs OR 7.40 kg.
Hope this will help you to solve thr problem & if my solution is useful to you please vote for it
Aug 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
I need to replace the filter in my Robinair 34700Z machine. Where is it located? And where can I find a manual to go with this machine? Mine is missing. . .right when I need it.
Press the main menu key,then upper arrow & go to "Change filter" option,then press "Yes" key & now follow on screen message(Do not skip any option while active ''change filter'' option).
Filter located on back side of the machine & fixed with the manifold assy.it's long black color & you may see the sticker with part no# 34724 (spin-on filter dyer).
For user manual you can try to robinair web official site www.robinair.com
Hope this will help you.
Apr 20, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
551 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
