Question about Woods Upright Freezer V1613RW3
I have a clear oily substance...no odor..leaking from upright freezer
2 Suggested Answers
  • 1796 Answers
SOURCE: kenmore leaking oil
Hi!!
You have a Refrigerant Gas (Freon) leak. Oil travels with the Refrigerant Gas thru the system, that's why you see the oil on the drip pans, if you look closely you should be able to know where is coming from.
For what you are telling me, it seems that the leak is of considerable size, I recommend to ASAP take freezer to a Kenmore authorized service station for a repair estimate, then you can decide to fix it or get a new one. If you call a repair tech, he will charge for the house call regardles.
Good Luck
Don't forget to rate this post.
Posted on Jun 04, 2010
FREEZER WAS WORKING FINE 5 years ago before we stopped using it because we didn't use it anymore. But i tried using it again this year, it turns on but will not work/freeze.
Hello;
My name is Peter. I am a retired field service technician.
You have not provided very much information, so I am going to make some assumptions.
First, you stored the unit either outside with a cover or stored it in you garage; both of which have drastic changes of seasonal temperature. This is bad.
Basic refrigerators and freezers are designed to be both store and operate in a controlled atmosphere, such as your home.
Not properly stored and with changes of temperature between night and day and winter and summer, creates condensation on all of the components as well as thermal expansion on the brazed seal system joints.
Well, let's check it out. I assume both the evaporator and condenser motors are running.
Unplug the unit. Remove the back lower cover. Feel around the compressor and tubing for a oily substance. If this is the case, then you have a refrigerate leak. This is a major repair and will cost $650.00 to $750.00.
Ok, no oily substance. Inspect for burned wiring from condensate.
You may also had condensate get to your control board.
It is difficult to say what the problem is because I am making experienced assumptions.
Do not discard this unit. The older units are better built. A service tech such as I to show up at your door is $79.00. I estimate this service call will be about $350.00.
Call me. Let's kick it around. 443-306-1362
Oct 16, 2014 | Freezers
Kenmore freezer leaking green
It's not refrigerant. Refrigerant would have evaporated straight away. What did you have in the freezer when it went off? It may be refrigerant oil, in which case mop it up with paper tissue and clean the area with detergent. It's no more toxic than any other oil.It's most likely to be excess ice/frosting leeching from inside the cabinet. Again, mop up with tissue paper.
Apr 28, 2012 | Kenmore Freezers
Kenmore leaking oil
Hi!!
Good Luck
Jun 04, 2010 | Woods Upright Freezer V1613RW3
Foul fish smell emanating from the freezer
Well an old remedy is to put a box of opened arm and hammer baking soda in the freezer and fridge to keep it from having bad odors.If that doesn't work you can try some charcoal it is perfect for absorbing odor, just don't use the matchlight kind or it will smell like lighter fluid.
Apr 06, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Bad odors
you need to do a full manual defrost,clean drains with clorine bleach and make sure all vents are free of s..t
do not use rapid defrost/or scrapers.at least 24 hrs switched off.then wipe out with bicarb solution and dry thoroughly,then your set for another year......
Apr 01, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Upright freezer shuts off and leaks when there is any kind of ice buildup. has done this twice in 7 months. is this normal or is it on its way out?
I suggest checking the defrost circuit. Make sure the drain in the back of the freezer is clear first. Then check the defrost timer, switch, and heating element using a volt meter. You can download a schematic from the Sears/Kenmore website.
Jan 19, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Trying to see if it has a drain plug
FILL 1 or 2 shelves with crumpled up newspaper . The ink in the newspaper , will absorb odor . May take a while , but it's the only proven way I know of , to remove fish odor . May have to change paper every couple of days , till the odor is gone .
Jun 16, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Freezer problems big time
Try putting a tray of crushed charcoal in there... a one foot by one foot tray about 3 inches deep filled with crushed BBQ briquettes (the kind that doesn't have lighter fluid in it!) left over night or longer may pull much of the "stank" out, and you can always do it again with fresh charcoal if it works but not well enough... Good luck!
Aug 17, 2008 | Freezers
Odor
i would take the machine outside and blast it with a hose. use hot water mixed with bleach and dish detergent to clean the inside  thoroughly.
Jul 14, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Mar 30, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Woods Upright Freezer V1613RW3 Logo
51 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
