Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
I bought the glowbouy last year. I replaced a bulb, charged it up and now it doesnt work. The light switches on for a split second when i go o switch it from off to light. The light goes on briefly then off but is off when its in the on position. Is there an internal circuit board issue?
I bought mine in 2008, used it once, and it has been on a shelf in my basement until this week. I did find a comment in the manual that indicates that the battery would need a 36 hour continuous charge to recondition the battery if it had not been on the charger for an extended period of time. I have another 24 hours to go before I know if it worked. Anyone out there still dealing with these issues? Or have found a place to get a replacement battery?
Posted on Jun 26, 2012
  • dfwagoner
    dfwagoner Aug 07, 2012
    It looks like we're all out of luck. My pool company called their distributor for me because she knew he had sold them at one time. However, he ran out of any stock that he had and told her the company was sold and these lights are not being made anymore. That means no warranties, no parts, and no service. Might as well take it apart and see what you can do on your own. I really liked this light, too (sigh) and noticed Walmart and Target are selling similar lights but I'd hate to put that kind of money out again if I can fix the one I have somehow. Good luck everyone.
Anyone know where to buy the replacement battery for the green glowbuoy. Have looked everywhere and can't find one.
Posted on Jun 11, 2011
  • 640 Answers
It sounds like your swimming pool light is not holding a charge. This normally indicates that the batteries have expired their useful life and need to be changed. Even rechargeable batteries are not designed for permanent use.
Posted on Jul 08, 2010
Hunter Regalia model 28642 light switch does not work.
Did you confirm switch is non-working? Possible bad connection between switch and light or switch & feed. Does remote work?
Apr 08, 2017 | Miscellaneous
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Feb 18, 2017 | Pride Health & Beauty
GlowBouy not lighting up, no matter how long charged
Most of the time, that is going to indicate a problem with the battery no matter what type of swimming pool lights you have, but you are in luck, because I have located a copy of the owners manual for this light. Hope this helps!
http://www.spawarehouse.com/IG/OwnersManual/PoolLight-gb_inst_manual.pdf
Jul 06, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I have a 1991 oldsmobile cutless supreme. the lights for the turn signal work but doesnt blink unless you manual move the switch up and down. also, the power window on the drivers side doesnt work but the...
the signal problem is probably a bad flasher unit.it's located somewhere near the steering column under the dash. it's a small round silver (usually) part with 2 prongs that plug into the connector
Feb 23, 2010 | 1991 Oldsmobile Cutlass Supreme
Please describe your issue or question (*) Last year we bought four of the Gemmy Color Chasing Light Show strings with the multi-color LED tear-drop shaped bulbs (#0293751). All four strings worked...
tombonw, I noticed this problem last year also, did the same string replacement as you, but by seasons end the new strings I bought had the same problem with a few doing something different. Did you ever find a good solution or hear from anyone else?
Dec 07, 2009 | Gemmy Toys
Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Jun 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
1998 tahoe brake lights don't work replaced switch still dont work touch and go
There is a clip that gets worn on the brake pedal that holds the switch tight to one side. It must be put on correctly or else the brake lights will come on for a split second and then go out when you push the brake pedal down further.
Jun 23, 2009 | 1998 Chevrolet Tahoe
Light doesn't work
if you have a remote control, check the switches inside of it... default setting is all four of them should be pointing upward.
Feb 27, 2008 | Dryers
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
549 people viewed this question
Top NRS Pool & Spa Experts
Ian Kime
Ian Kime
Tom Chichester
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
