Champion 42CVI 42'' no picture, only gray screen, what may it be?
  • 1 more comment
  • Ronildo Girardi Jul 07, 2010
    I am a technician, I am repairing my plasma tv, CV14200 champion plasma screen 42".\r\n
    I replaced already sc borad that was visible blown up and image gray with no picture it shows me!
    Then I replaced the D1, the first board that has the sound card built in and nothing .....
    No picture, no menu functions, all I got is a gray\black screen light up, nothing more!
    what is the voltages that must be adjusted in this plasma tv?
    how to test su and sd??????????????
  • 6,993 Answers
Hi
The fault is from the picture board of your TV.
Take care.
Posted on Jul 14, 2010
  • Ronildo Girardi Jul 14, 2010
    Ok, in order to this be usefull, you must specify what board? the main board was completely replaced, the sd and su board are ok, there is not a problem on power supply as the voltage is alright on all the boards.
    so, I suspect it is missing a cable.
    Ok, first I sent to a company to repair it, they returned to me
    "unfixeable" as there was not this Board here in Brazil.
    Then, I begin to get the board that was visible burned (sc board) and installed on it and calibrated the voltage on
    potentiometer values that has writen on own plasma screen.
    The lights from both SC and SS board remains lit all the time, I can
    see the plasma backlight on (gray screen) but nothing happen on
    picture, even if I press the menu option it just "blink a smooth shadow"
    and nothing happens, it remains "gray".
    There is not visible sign of bad caps ON ALL CAPS ......
    Now,
    I am in doubt if is it missing cable connectors? maybe the "stupid"
    guys that tried to repair first time, forgot to install back the cable
    that comes from "D2" to the last bord you sent me "D1".
    IS THERE ANY CABLE THERE? BECAUSE THERE IS NOT A CABLE FOR ME TO
    CONNECT TO IT ....
    ON "D2" BOARD THERE IS TWO SOCKETS THAT NOTHING IS CONNECTED TO IT, THERE IS
    A NUMBER IN IT "D24 AND D7".
    IS THERE A CABLE THERE?????? IS THERE AT LEAST SOME DOCUMENT WHERE I
    COULD CREATE A LINK CABLE FOR IT????
RCA TV, Model L42FHD37. Gray or black bars on either edge, but not getting the entire picture. If I "zoom" I still can't see what is obviously behind the black or gray bars.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Jan 20, 2016 | RCA L42FHD37 42 in. LCD HDTV
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
Sound ok no picture hp invent comes on then the screen goes gray
Display or its board has got affected partially and might require the attention of a qualified service technician.
Jul 30, 2012 | HP PL4260N 42 in. Plasma HDTV
How can I connect a WII console to my Champion Plasma CV 142 TV set? Can I connect it with RCA cables?
The 42CVI has both composite and component video in the standard configuration. Either of these should connect to your Wii console. You will get better results if you use component video (3 RCA plugs on each end of the wire for video (Y,Pb,Pr); use a second cable with two RCA plugs on each end for audio.) The Component video is Input-4. The component video cable is usually not provided with the game console. There are 2 composite video inputs on the TV (these use one wire with 3 RCA plugs on each end of the cable for video (yellow) and audio (red and white)).
I hope this helps.
Apr 09, 2011 | Champion 42CVI 42 in. HDTV-Ready Plasma...
Gray bars on side of picture
Yes. There are options. Strech, wide, full, zoom, and gray bar are common options. Some times when aa HD channel is not broadcasting in HD you will also get a narrow picture.
Apr 30, 2010 | LG 42LG50 42 in. LCD HDTV
Gray bars while full screen viewing my Broksonic CCVG-4500 42 in
hi, i have a broksonic model ccv-4500 , these is a monitor or tv because i cant founder the digital cable imput. thanks.
Apr 25, 2010 | Broksonic CCVG4200 42 in. Plasma TV
Picture is too big for screen
You will have a button on the _original_ remote that says Format, Aspect Ratio, Zoom, Size or just AR. It will cycle through Normal, Stretch, Partial Zoom, Zoom, Gray Bar, or the like. You are not in Normal but in one of the Zooms. Stretch is used to make 4x3 movies fill a 16x9 screen, may not be desirable. Zoom is used to fill the 16x9 screen with movies that have been letter boxed. Gray Bar fills the sides of a 4x3 picture on a 16x9 set with gray to "avoid" burn in. Use normal except zoom on LB. -Ken
Oct 04, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Lg 42lb1dr tv cuts off no picture or sound. gray screen.
There are 4 capacitors on the power supply board that need to be replace. They are in the same area, same color, look for bulged caps.
Jul 15, 2009 | LG 42LC2D 42 in. LCD HDTV
Gray Screen
Them main video processor driver board may have to be replaced. It is also possible that the power supply may have a fault.
The factory service tech will try the modules to test for which one has failed, and then leave in the module that fixes the fault.
Jerry G.
Mar 26, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
