Question about Dell Latitude D531 Laptop Computer PC Notebook
When I turn on the computer, the screen does not light up. I can sometimes just barely see some writing or a box, but nothing I can use.
  • lagersmith Jul 07, 2010
    I have also tried removing the power cord, battery, pressing the on button for 30 seconds and plugging the cord back in without the battery. Doesn't work.
  • 69 Answers
I would assume you have used the FN and brigtness up button,
If this has not solved your problem it would more than likely be the inverter on its way out,, the inveter is located at the bottom middle of your screen bezel and would be best repaired by a professional as high voltage can be exposed
Posted on Jul 10, 2010
Why when i cut my laptop on it turns on then screen goes dim then turns black after a few minutes
Had you recently charged your battery? how old is the computer and the battery? If you write again, please tell us the make and model of your laptop.
May 20, 2014 | Gateway NE56R41u Dual Core B960 4GB 500GB...
I have barely used my BR-900. I love it, but now the display screen only works occasionally. All writing on the screen will actually disappear while I am performing a function. Sometimes turning the...
I hate to say it, Sandra, but that problem usually doesn't involve an easy/cheap fix. I run a 1200 here, so I know from whence you speak. If this is an "under warranty unit", I'd box it up and swap it out.
BUT, if not, and you're any good at dis-assembly/re-assembly or know someone who is, I HAVE fixed problems like this with the "pressure" method. It worked on a Chevy digital dash that was blanking out on me and a couple music keyboards.
Power it down and unplug the power cord, dis-assemble it to the point you can see the board that feeds the display. Very carefully plug the power cord back in and power it up. While avoiding touching any of the boards or connections with your bare hands/fingers, use a pencil eraser and lightly apply pressure to different spots on that board until (maybe) the display lights - indicating a loose connection; probably a bad solder joint in that area. Trying to repair it would probably fry it, unless you're an ace solderer.
Now, the trick is to remember that spot, use a piece of non-conductive material, like a small wad of electrical tape big enough that it would apply a similar constant pressure to it at that point once it's re-assembled. I know - sounds bizarre, but I've made it work where soldering was impossible without a professional teardown.
Good luck,
jim
Mar 11, 2014 | Roland Boss BR 900cd Digital Recorder BR...
Computer screen barely visibleL
Take it to the shop. Your Motherboard has a problem.
Oct 08, 2013 | Lenovo ThinkStation E20 4222 P G6950 8 GHz...
Light on monitor is green when turned on, but then turns orange with nothing on the screen. I can hear the computer running though.
your monitor is not recieving a video signal from your pc. check your connection to pc, then check things like bad memory card, etc. sometimes just shut pc on and off a few times clears this up.
Jun 03, 2009 | Computers & Internet
Screen stays blank when turned on
take your computer to your dealer and send it for repair.
The problem is most likely the inverter for the screen.
actually to see if that is the problem you can try to put bright light to the screen and see if you barely see the picture.
May 28, 2009 | IBM ThinkPad R51 Notebook
Can't see the screen!!!!
Either the backlight on the LCD has failed, or the video inverter which provides power to the backlight have failed. Either way, the computer is under warranty; contact HP and have them fix it; it could get costly to do it yourself.
Apr 27, 2009 | HP Pavilion dv5-1132us Notebook
No screen at start up
either you darkened it or the back light went out. try the briten it with the FN key
Dec 05, 2008 | Toshiba Computers & Internet
Cannot access any programs on Toshiba Satellite A135-S4517
Either a tune up, or it has a faulty hard drive. If you can manage to get to My Computer, right click your C: drive, select Properties, go to the Tools tab and click Check For Errors. Check all the options, and start it. It will tell you that the tests can only proceed when you reboot. Check it in order to do so and reboot.
Good luck.
Oct 28, 2008 | Toshiba Satellite A135 Notebook
Computer monitor screen remains black
try giving the monitor a hot slap or spank at the back, believe me, you'll be surprise, you've got nothing to loose
Jul 20, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Bad Song caused screen to go blank!
move the button HOLD switch ON,to see orange.Hold down REC button and with the REc button holding down,connect the player to the computer.this is Recovery Mode.If your computer recougnize your plaer like 16mbFormat,everything is ok,in this case do as i say in the following text.(if it doesn't been recougnized by the computer...i can't help you)Go to START-PROGRAMS-ACCESORIES-NOTEPAD.IN the new text notepad,do not write anything,go to file-save as.In the box "Save as type" select "all files" and in the box "file name" write :sansa.fmt
Save the notepad file on desktop and copy it in your "16mbFormat"sansa player in recovery mode.16mbFormat is the name of your player in recovery mode wich you will find in My computer.Do not copy anything at there.like music or other files.after that disconect your player and enjoy.this is FORMAT in Recovery MOde.
Feb 14, 2008 | SanDisk Sansa e250 MP3 Player
Dell Latitude D531 Laptop Computer   PC Notebook Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
