Mitsubishi xc-3716c monitor
Very high end monitor, 1280x1024 res,rgb inputs,need advice on digital tuner selection.what is ttl mode? any advice welcome,just want to save this from the analog graveyard. searched the net for info on this unit,not much to be found. help!
    Genius:
  • 1,665 Answers
Model (XC-3716C)
Manufacturer's product description
Mitsubishi represents the pinnacle in technological achievement for multi-person viewing of workstation generated, high resolution imagery such as CAD/CAM/CAE or scientific visualization. With its 37" (35.0" diagonal viewable image) flat-square CRT, Dynamic Beam Forming for improved image definition at monitor screen edges and with exceptionally sharp 1280 x 1024/75 Hz non-interlaced addressable resolution that is bright and bold even in high ambient lighting, the monitor delivers unparalleled performance and versatility. It also comes equipped with stereo sound and operates from virtually any worldwide video standard, plus compatibility with today's most popular graphics standards. Front control panel or multi-function wireless remote control (NOT INCLUDED) and on-screen display of all set-up functions make control adjustments, as well as input selections, easy and accurate. The XC-3716C color display monitor will truly make your next technical presentation sizzle with unforgettable impact. This unit was built in 1995 and has not seen any serious use since the year 2000
General
# Display Type: Presentation display / CRT - stationary
# Width: 34"
# Depth: 23"
# Height: 29"
# Weight: 209 lbs
# Enclosure Colour: Gray
# Compatibility: PC, Mac, Unix
Display
# Diagonal Size: 37"
# Viewable Size: 35"
# Max Resolution: 1280 x 1024 / 75 Hz
# Colour support: 24-bit (16.7M colours)
# Max Sync Rate (V x H): 120 Hz x 85 kHz
# Factory Preset Resolution Modes: 1280 x 1024 / 75 Hz
# Front Panel Controls: Power on/off, adjust +/- , colour adjustment
# On-Screen Controls: Contrast, brightness, H/V-position, H/V-size, degauss, trapezoid, parallelogram, OSD-position, colour temperature selection, audio volume, speaker on/off, select
# Features: Invar shadow mask
# Compliant Standards: UL, CSA, DHHS, PTB, FCC-B, FCC-A, VCCI-I
Video input
# Analogue Video Format: NTSC, SECAM, PAL, M-NTSC
# Analogue video Signal: RGB, S-Video, composite video
Audio output
# Type: Speaker(s) - integrated
# Sound Output Mode: Stereo
# Audio Amplifier: Integrated
# Speaker(s): 2 x right / left channel
Connectivity
Port(s) Total / Connector Type:
* Audio - line-out
* 1 x - 1
No burn ins - Crystal Clear Picture
Accepts RGB input with special cable that is provided
VGA inputs for computers and such
Posted on Apr 28, 2008
  • 180 Answers
Ttl is in short from Transistor-Transistor Logic.
Posted on Apr 19, 2008
Mitsubishi tv dvi
If your TV has a HDMI input plug your HDMI cable into that, then select HDMI on TV. HDMI means HIGH DEFINITION MEDIA INTERFACE and DV means DIGITAL/VIDEO. One is HIGH DEFINITION the other is not.
Dec 18, 2013 | Norcent Technologies Computers & Internet
Moniter
Right Click on your desktop, then select properties. Then Advanced tab. Then you need to change your screen resolution. There will be a little slider that you can move left or right. Move it until you get it to the 1280x1024.
Sep 22, 2007 | Samsung SyncMaster 710VT TFT LCD Monitor
"Input signal out of range"
usually points to the resolution settings of the graphics card not matching the monitor resolution settings. Reboot to safe mode on the computer and set the resolution to a lower one. A good starting point would be 1280 x 960 at high res. See if that works
Jul 09, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Apare imainea si apoi input not suport
The PC video resolution is too high for the monitor to display, you need to set it to 1280x1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Jan 13, 2011 | Acer AL1717 17" LCD Monitor
Montior says input not supported
The PC video resolution setting is too high for this monitor to display. The native resolution for this Dell E172 is 1280x1024260Hz, that is what you need to set your PC Video to. Boot up you PC in safe mode (hit F8 during boot up) and select bootup in VGA, set the resolution to 1280x1024, then reboot.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 21, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Monitor say Input not supported. What does this
Your graphics card is set to a resolution of refresh rate that your monitor cannot handle, This can sometimes be one of the normal settings - there is not much you can do. Each monitor has a native resolution which the monitor should always be set at yours is:- 1280X1024
Nov 03, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
I am getting an error not optiumum mode recommended mode 1280x1024 60hz
If you right-click on the desktop and select 'properties' and go to the 'Settings' tab you will be able to use the slider to change your monitor resolution to 1280x1024.
If you then select the 'Advanced' tab you will see a setting somewhere which refers to the screen refresh rate. Change this to 60Hz.
This should give you the best picture settings on your monitor.
Oct 16, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
Computers & Internet Logo
708 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
