Question about Canon DR-2580C Path-Through Scanner
Scanner cover is open
I keep getting the error "scanner cover is open" when the cover is closed. Any suggestions?
5 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Posted on Feb 06, 2008
SOURCE: When attempting to print, I
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
Posted on Jun 19, 2008
IrishDruid
  • 2712 Answers
SOURCE: problem with my Canon Pixma MP500
Try a hard reset first: Unplug the printer from power source and PC, wait about 5 minutes and replug. Should the issue recur, then the cover sensor is probably faulty. That is the reason you are getting this error repeatedly. The only solution is to send the printer in for servicing and get the sensor repaired/replaced.
In any case, here are the steps to close the inner cover:
1. Press the Open Button (1) to open the Paper Output Tray (2).
2. Raise the Scanning Unit until it stops.
3. Close the Inner Cover
4. Now close the Scanning Unit.
You can also try reinstalling the printer software along with any patches, updates, etc from the Canon website. Make sure you uninstall the existing software first though..
If neither works, then its time to take the printer in for servicing. You could try to contact them by phone first:
  • Toll-free live technical support** Monday through Friday 10:00 AM ET to 10:00 PM ET (excluding holidays) at 1-800-828-4040
  • The location of the ASF nearest you for carry-in service at 1-800-828-4040
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
Hope that helps!
Posted on Jul 03, 2008
  • 5 Answers
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Posted on Dec 18, 2008
Red paper light keeps flashing. Closed all doors, turn on and off
Close the front cover. If the error is not
cleared even after closing it, open the cover
once and close it again.
The error may occur because of the laser
BD malfunction. The Laser unit may need to be R/R'd
Try cleaning the Scanner Window
When replacing the drum unit or toner cartridge with a new one, be sure to clean the scanner
window.
1) Turn off the power switch and unplug the power cord.
2) Remove the drum unit from the printer.
3) Gently wipe the scanner window with a soft dry
CAUTION:
· Do not touch the scanner window with your fingers.
· Do not wipe the scanner window with cleaning alcohol (isopropyl).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
cloth.
Feb 10, 2011 | Brother HL-2040 Laser Printer
Printer will not print showing error 2200. How do l fix it?
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
On our Canon 6080, we get an error C01. We have opened and closed the main compartment several times, but the error does not resolve. My IT guy is out with the flu. Any help would be appreciated.
When top cover is open, you get a display C01. Press the top cover and check if the display goes off. The top cover is held in position by a spring loaded mechanism (The grey colored plastic part No MA2-6863-000) The spring is held in position by a small plastic tab and this was broken in two of my scanners. I used a self tapping screw in place of the plastic tab to keep the spring in position.
S. Mohan, Chennai, India
Sep 08, 2010 | Canon DR-7580
Kodak i40 error e7
E6 means the scanner cover is open .
Please check for any open covers or any movable parts which is not closed.
Feb 26, 2010 | Kodak i40 Path-Through Scanner
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
What is Error 2200 when I try to fax something?
Error 2200 is a scanner stall error.. there are a couple things for you to try to fix it:
Power off the AIO and remove the power supply(Power Cord) from the back of the unit.
Open the top cover of the AIO.
Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Power off the AIO and remove the power supply from the back of the unit.
Close the top cover, reinsert the power supply, and power on the AIO.
Jun 29, 2009 | Lexmark X7170 All-In-One InkJet Printer
The scanner cover is closed, however I get an error message saying it's open. The unit will not print, copy or scan
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
Jul 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Error 2200
Maggie B
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Canon DR-2580C Path-Through Scanner Logo
211 people viewed this question
old marine
old marine
