Question about Dell (002TR) Motherboard
My computer does not let reboot in none of the reboot options?hdd,cdrom,patition none of them wats wrong?
    Problem Solver:
  • 18 Answers
Must have messed up the CMOS reboot sequence. Enter the CMOS menu screen. Go through the menus and look for "Boot Sequence", and set this to your primary HD for now.
Once you get your system up, you can change the Boot sequence to CDR first, followed by HD.
Posted on Jul 07, 2010
Boot with pandrive
ashishkhare2,
This computer does not allow booting from a pen drive. Below are the boot options for this system.
Boot <First, Second, Third> device: Diskette Drive, Internal HDD, CDROM Drive, Modular Bay HDD, OR NONE
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 18, 2013 | Dell Latitude CPI-A Notebook
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
New Hdd will not install os. Gets to place in install where it needs to reboot. It reboots then the cursor just blinks. Does the HP have a compatibility issue with certain Hdd's.? Can I replace the old...
You have not set the boot order options for the PC to CDROM>HDD. You need to command the computer to start from the CDROM coz now its starting from the not yet installed drive. So, on the PC's boot screen, press f10 or del, whichever for your PC in order to enter the Bios setup. In it, look for the Boot order and set the options as cdrom then hdd.
Restart PC. Please let me know if it was of help.
Dec 06, 2010 | HP Compaq d530 PC Desktop
ASUS M2N68-AM SE2 GeForce 7025 Socket AM2+ MB built system. Works great with Sata hard drive. Removed my older 500GB IDE hard drive and CDROM from old PC. When i try to put both, or either 1 into to IDE...
Try to go into the bios and set the first boot device as your sata hdd. There will be a option in boot section of the cmos setup where the hdd drive order will be mentioned. If PATA is shown first press enter in the option select SATA and press enter save and exit changes things should go on fine.
Also check your pata hdd and cdrom specific jumper setting. For more help post your HDD model and make and cdrom model and the bios type
Dec 01, 2009 | Computers & Internet
On boot up laptop states it can't find the operating system
this sounds like you need to repair the boot sector. this usually happens when a hard disks boot sector becomes corrupt or damaged. to fix this you must use the windows install disk to install recovery console. put the disk in the CDROM drive, reboot, (you may need to press F2 upon bootup to enter setup and choose to boot from the CDROM instead of HDD) once computer is configured to boot to the CD drive reboot and choose "repair" when prompted by the cd. once the repair prompt is up you must run the 'fixmbr' command which will copy boot files back to your computer. hope this helps. please rate me and thanks for choosing enterprise computing solutions.
Oct 06, 2009 | E-Machines eMachines Desktop PC
I just receiver recovery and system disc from Acer to restore my laptop to factory settings. I tried couple times and followed the instructions. The recovery disc formatted partition 2 on the computer but...
Looks like your recovery cd is corrupted. You must obtain a copy of Ms Windows cd and install it using the license from the back of your laptop.If that doesn't work either its a hardware related (hdd) problem.
Aug 19, 2009 | Acer Extensa 5620-4677 Notebook
Realtek rtl8139 (X)/8130/810X PCI FAST ETHERNET CONTROLER V2.13 020326. PXE-E61 MEDIA TEST FAILED CK CABLE AND PXE-MOF EXITING FLASHING CANNOT DO A RESET WITH F9
Hello khulsey60,
The above message is mainly informational and doesn't necessarily indicate a problem. The acronym 'PXE' stands for Preboot Execution Environment. It's an environment to bootstrap computers using a network interface card. Usually the reboot is done by a remote computer on a LAN (Local rea Network). The Realtek NIC (Network Interface Card) somehow expected a PXE boot to be taking place when the computer was restarting. One solution is to restart the computer and go to the boot menu (F2 on some systems) and choose to boot from the master drive.
*Here's a link to a good article explaining what PXE is: http://www.search.com/reference/Preboot_Execution_Environment
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Acer Aspire 5100 Notebook
Primary Hard Disk Drive Not Found, Fixed Optical drive Not found
Reseat both the Hard Drive and Optical drive and see if they detect. If they do not, then a HDD failure is most likely. The I8000 is quirky in that if the HDD fails, the Optical drive will not work.
If reseating doesn't resolve, Replace the HDD and the optical drive should work. (Controller is a serial design and neither drive will function if the other fails)
Jan 19, 2009 | Dell Inspiron 8000 Notebook
New 120G HDD can't be partitioned
smtimes d RAM didnt support the harddisk can u tell me wats ur computer RAM......
if it is between 500MB-1GB then it is suitable for it if it is lower, than it will not support ur harddisk....
n also smtimes harddisk quality can also cause error.....
it should be same as older one.......
Jun 17, 2008 | Compaq NC8000 Notebook
Dell (002TR) Motherboard Logo
mukhtar21 shaikh
mukhtar21 shaikh
