Question about Cal Flame 5-Burner
Converting to natural gas
Is there an orifice for the rotisserie to convert to natural gas
    Champion:
  • 274 Answers
Yes, all burners will have an orifice to control the amount of gas flow.
Posted on Jul 13, 2010
Convert to natural gas
To convert the heater to natural gas you will need to change the orifices in the gas unit to natural gas. I am assuming you now have it on LP gas. Hope this helps. You should have someone who knows to change the orifices over. Most appliance parts dealer carry them.
Jul 18, 2016 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Converting Bosch HDI7282U/09 back to natural gas / orifice sizes?
they are set sizes and you need to change the air shrouds as well to get proper burn
this is a job for an accredited gas fitter so call one in and he will
have the correct jets and be able to adjust the air shrouds as well
Nov 10, 2015 | Bosch Kitchen Ranges
I would like to convert a grill that was used on natural gas back to propane. Can I just purchase a regulator and hose and be good, or do I need to change anything else on the grill?
Burner orifices must be resized or adjusted to accommodate higher pressure LP.
Air shutters should be opened all the way to allow maximum air to gas ration.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 14, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Char-Broil Advantage 463453306
I dunno, I have not done the conversion for this particular barbecue, but the kit is listed in the parts list for that barbecue,
It would be appropriate at this time to print the conversion instruction manual and take it to a local 'guy' a gas fitter.
The instruction .pdf shows them converting 3, 5, 7 burner units with the same kit, and states
  • Insert orifice removal tool provided with kit onto firebox burner openings and unscrew orifices from valves.
    Save removed orifices for later if converting back to LP Tank Gas.
    The valves are designed to work with natural gas once orifices are removed.
    Do not replace any Orifices when using natural gas.
    NOTE: your gas conversion kit comes with replacement orifices for the Rotisserie Burner ONLY, do not use on Tube burner valves.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/assembly%20manual%20-%204584609%20ng%20conversion%20kit.pdf
seems the same 2-burner kit is for all barbecues
I think the person on the phone messed up, but a gas-guy would know for sure
Jul 01, 2008 | Char-Broil Advantage 463453306
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Cal Flame 5-Burner Logo
Top Cal Flame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
richie46
Are you a Cal Flame Grilling Expert? Answer questions, earn points and help others
