Question about Craftsman Garden
Wont start have topress primer butten then it starts but wont keep running
  • 84 Answers
Your carb. needs to be taken off motor, taken apart and cleaned. Has dirt in it and plugging ports so gas cant get to carb., just the bowl
Posted on Jul 10, 2010
  • brian
    brian Mar 17, 2014
    thank you but its all the bits that fix to the carb I can't remember what goes where can I get a plan what goes where please
Fuel pump keeps priming. wont shut off
Pump still runs because hasn't started and is in cold start mode. Get power to the coil to get it running first, then see if the pump shuts down when switch is off.
Oct 12, 2014 | 1996 Ford Thunderbird LX
I have a 2000 Hino Dutro wont start changed diesel filter and still wont start
changing the filter wont help,you need to change the filter / primer housing unit.happend on an isuzu i worked on about 3 years ago.changed the whole unit and it worked like new.
May 08, 2012 | Cars & Trucks
Toro 22" cut starts. to
a hole in the primer bulb or gas line it could be a pin hole right in the primer bulb itself and when you hold the bulb you might be holding the hole itself which keeps it running....
Jul 14, 2011 | Garden
The compressor turned on pumped up and shut off and wont start up
Inccrease the line pressure to 90 PSI, a air ratchet is a very high volume air tool and the compressor may not be able to keep up with it.
Jul 14, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Runs but wont idle / Homelite330
Try adjusting the idle. The will be a couple adjustment screws, there will be an (H) and (L) you will need to turn the (L) First tighten the sdcrew completely then turn it 1-1/4 turns. This will be a good to start. Then just turn it small amounts until you get it to idle. Also there should be an idle adjustment you can adjust.
Jun 06, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Procedure for starting
Thats called the primer Make sure the on/off switch is on the on,Push the primer at least 4 to 5 times,then pull it..once it starts you may have to push the primer a few more times to keep it running once it runs on its own and you dont have to push the primer to keep it running Cut Away,Also one more thing you probably already Know make sure its full of bar oil..Hope this helps you and have a great day...
Apr 06, 2009 | Garden
Wont stay running
Try pumping the primer till it's full of fuel, then start the saw
Apr 03, 2009 | Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
