Samsung LE37M86BDX LCD TV. Just wondering if you had any "optimal" settings for picture and sound etc?? Many Thanks.
    Sergeant:
  • 308 Answers
If the picture looks good, I wouldn't touch a thing, usually I end up cutting down the brightness a bit with a new set out of the box, and adjusting the contrast to suit my tastes. Sound is probably good as is.
Posted on Apr 18, 2008
Sharp 52" LCD-Negative picture
hi bring the menu up if it's the same as the picture, the mainboard could be the problem, also can be a bad panel thanks
shaun
Mar 04, 2017 | Televison & Video
Just did. Where did it go? Remote control does
Not the remote,it is the tv itself.Now,turn on the tv it have a flashes of pictures only a few sec. than dies and have sound left only?Yes,than the tv have a 1 or 2 long board call the LCD inverter boards,they are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 refurbishes long LCD inverter boards for the replacement.
Dec 10, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Samsung lcd TV five years old, screen suddenly went black
In order to properly provide you with guidance, we need some hint about the problem. Can you describe the symptoms? Is the set dead? Are there any blinking status lights?
Thanks,
Dan
Sep 20, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung LE40R
try to change the stantard from the channel setting menu(bg-dk etc.)
Jun 27, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
No sound
There are two quick things to try:
1) The TV's speakers may be turned off. To turn on: Press MENU, select "Sound Settings", select "Internal Speakers", then select "On" (as opposed to "Off"), and then EXIT.
2) The Sound source may be set to PIP (picture in picture) instead of Main picture. In that case press MENU, select "Picture", select "PIP", select "Select Sound", then select "Main" (as opposed to "Sub"), as the source of the sound, and then press EXIT.
Whatever PIP is set to may not even be connected to the TV so there would be no sound.
The terms and menus used here are from Samsung so they will be different from yours but the concept is the same.
Good luck,
Techjoel
Apr 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
Samsung LE46F8 picture setting
It sounds like your TV is in Shop Mode.
Shop mode is a set of picture parameters that have been optimized for a store showroom or display floor. Shop mode does not allow you save any picture settings such as brightness or contrast.
To get the TV out of Shop Mode press and hold the Menu button on the front panel for three seconds, the picture will blank momentarily then reappear with “Dynamic Mode” shown on the screen. At this point the picture parameters can be changed and saved.
Feb 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Optimal Settings
There are no perfect settings. Most people leave the controlls in the middel. The controls are for you to adjust the picture to where you like it the most. Keep in mine that the picture can be different from one chnnel to the other. Try to find a happy medium for all channels.
Jan 19, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
LCD TV with broken screen, good picture??
samsung.com says it has to be repaired by local dealer. get quote first. probably cheaper to just buy a new one.
Jan 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Nov 13, 2007 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
