Question about Frigidaire Electric Dryer
THE DRYER IS VERY WARM BUT ITS NOT TURNING. I
THE DRYER IS VERY WARM BUT ITS NOT TURNING. I HAVE TO UNPLUG THE DRYER FOR IT TOO COOL DOWN
    President:
  • 3,085 Answers
It appears that the drum belt has come off or has snapped.
Posted on Jul 06, 2010
Dryer is to hot won't cool down
That sounds like a big problem unplug it.
Dec 23, 2013 | Maytag Dryers
LG DLE5977s electric dryer drum not turning when warm
Could be one of the "overheat thermostat switches" has failed, or is failing.
Could also be a big buildup of lint inside the machine (where you cannot see it) causing the switches to trip.
In the back or the bottom of the machine are from 3 to 7 "overheat thermostat switches" that are put there to prevent fire.
When the get hot, if they are bad, they will shut off the dryer until they cool off.
Kinda sounds like one is "trippin' ". If you choose to fix it yourself, you'll need a good electrical test instrument and several tools to take it all apart.
A question to "fixya" might get someone to tell you how step-by-step.
Be blessed.
Mar 27, 2013 | LG DLE5977 Stainless Steel Electric Dryer
My Hotpoint gas dryer won't relight after it has
Your gas valve electrical coils have gone bad. They are easy to replace.
Jun 21, 2011 | Hotpoint Dryers
Crosley cde6000w. was running fine, quit while drying clothes. machine was very warm to touch. still had power to control knob, buzzed when turn knob to end of cycle. let machine cool down and still will...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 17, 2010 | Crosley CDE6000 Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
My dryer will only stay warm for a brief time and then simply runs with cool air.
Those gas operating coils will get hot and quit and cool down and work some more. Intermittant little suckers. Some Repair Pix
Bonus stuff:
More Gas Dryer Enlightenment
Aug 31, 2009 | Frigidaire FGQ332ES Gas Dryer
AC not cool
Check the a/c lines entering the firewall. Large hose should be cold and small line warm-hot.If o/k, may have vacumm leak to underdash control. If vacumm is lost the system will revert to heat and defrost. Could also be the air blend door is stuck. Maybe something dropped down defrost vent on dash. If this helps Please rate
May 01, 2009 | 1992 Pontiac Bonneville
Difficult to start again after warm up engine.
give the engine a minute or two to cool down before turning it off. This cool down period allows oil to circulate and cool down the bearings in the turbo. If you shut off the engine immediately after hard driving, the oil can gum up around the hot bearings and create problems down the road.
Hope this helps
Thanks for using Fixya
Have a nice day!
Mar 05, 2009 | 1995 Honda Civic
Dryer not going to cool down cycle, thermal fuse failed 2x
Most problems like this arise from air flow problems. You need to break down the dryer and clean out the lint. Including removal of the filter housing.making sure your outside vent is clear as well.If that fuse keeps blowing you especially need to remove and rinse out that filter housing.
Dec 30, 2008 | Whirlpool LER4634J Electric Dryer
LG 20LS7D TV
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
then the fly back unit is failed you need to resolder the contacts or get it serviced...............
Jun 08, 2008 | LG RE-20LA70 20 in. Analog TV LCD...
Frigidaire  Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
