Question about Fuji FinePix S2 Pro Digital Camera
How do i fix high saturation - Fuji FinePix S2 Pro Digital Camera
    Champion:
  • 241 Answers
Press the Func. button to diplay color modes in the little display.
When the display shows Color to the far left, you can switch color modes on the button below. STD is standard saturation, HIGH is high saturation, ORG. is less saturated that STD, and finally B/W
Posted on Jul 09, 2010
What is fault code SA 16 DTC PO 4D900
Looks like could be caused by one of several sensors.
I did find thisP04D9 EGR feedback saturation This OBD monitor indicates if the burned air fraction error is saturated against a high or low limit. The logic for the monitor evaluates the time spent at saturation and compares the ratio between the time spent in a saturation mode and the total time engine running. A fault is reported whenever the ratio exceeds the fault limit.
P04D9 EGR system: Feedback control(Saturated Low)
Enable conditions: Engine torque 300 - 2500NM,Exhaust Mass Flow 0.1 kg/s, Ambient Air Temperature-8 -55C, Barometric Pressure 75 - 105 kpa, Coolant Temperature>65 C
Disable Conditions No active DTCs P0069 P046c P0234, P0299, P0401, and P0402
Some possible causes
P0069 Intake manifold pressure sensor evaluation
P046c EGR differential pressure sensor: DP Sensor rationality
P0234 Comparison of actual boost pressure, Overboost, to modeled boost pressure
P0299 Boost Pressure: Underboost, Comparison of actual boost pressure to modeled boost pressure
P0401 EGR system (low flow)compare demanded egr flow to actual
P0402 EGR System (High Flow)compare demanded egr flow to actual
Aug 20, 2017 | Cars & Trucks
Epson cx9400fax error waste ink is saturated
Get the User Guide from the Epson site for your printer. If that doesn't tell you what to do go back to the site and ask the question.
Oct 16, 2014 | EPSON Stylus CX9400Fax Series
I have the correct Manifold Gauges for checking the low and high side of the heat pump. How do I read the gauges to ensure that my system has the right charge? Outside ambient temperature is 85.4.
In order to know if you have the correct charge you must measure the subcooling since it is a txv unit. The outside unit will have the proper subooling you need printed on the data plate. Hook up you gauges and let thebunit run for 10 minutes, after 10 minutes check the high side pressure, that high side pressure will correspond to a saturation temp, write that number down then measure the temp of the liquid line and subtract the saturation temp from the liquid line temp, it should be the same as printed on tjhe data plate if it is higher than that add refrigerant untill you get whtas printed on tne data plate. Is there is no data plate use 12 degrees of subcooling.
May 27, 2011 | Heating & Cooling
My Epson D92 printer is showing "waste inkpad saturated" How can I fix this?
Take the printer to a qualified technician, and have them "empty" (or replace) the saturated pad -- it's like replacing a wet bathroom towel, but in "miniature" -- either you wring it out, dry it out, or you get another towel from your linen closet.
Nov 11, 2009 | Epson Stylus D92 InkJet Photo Printer
Color Saturation
I have the same camera and felt the same way about the colors. You can adjust the saturation slightly in the camera settings by going to the menu then down to paramerters. I find that it doesnt change the saturation too much though. Also try playing around with the white balance. AWB is not always the best. If all else fails, shoot in RAW and use photoshop, that's what the pros do.
Sep 14, 2005 | Canon Digital Rebel XT / EOS 350D Body...
Fuji FinePix S2 Pro Digital Camera Logo
79 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
