Question about Dryers
Our tenant's Whirlpool dryer motor failed, out of warranty, and are claiming our electrical system is somehow responsible. I asked them to explain how that is possible, but have had no response. My tenant is upset with me when I feel it is Whirlpool he should be upset with or the dealer who is trying to evade responsiblity.
  • john356 Apr 18, 2008
    The voltage is 110 on each leg and 220v across the 2 hot terminals. The repairperson is claiming that our electrical system somehow shorted out the motor! Of course, our poor tenant is upset and thinks the building is ready to blow up.
    It is newer wiring protected with a Cutler-Hammer 30amp double breaker.
    Thanks
  • 145 Answers
Real high or low voltage may cause a motor problem but this is easy to check with a voltmeter at the outlet. If they think it is a power problem there is no sense putting a motor in it until the problem is taken care of.
Posted on Apr 18, 2008
  • James Davis Apr 18, 2008
    That's what it should be. I would ask the repairman if he wants to pay for the electriction to come out if no problem is found with the power in the house. I have only seen one dryer problem that was from the power. But is was the power coming into the house that was way to high. The power company had to come out and replace the transformer.
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Hi,Dryer wont restart
def. sounds like a bad or failing motor situation... motors cost anywhere from 125 to 200 dolloars... not too hard to replace though....
Sep 24, 2009 | Whirlpool LER7646E Dryer
Flashing f11
Hi
F11 is a Serial Communication Error i.e. communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly. You need to
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • Please do rate the solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 26, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
    Coin-operated dryer won't turn off at end of cycle.
    A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
    Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
    3 Compressor in 6 years. Is this normal? As a consummer iam left with no warranty and support...
    Multi-Compressor Failures
    1st time a compressor fails the service tech is suppose to determine the cause of the
    Failure and fix it. Is it no oil return or oil being washed out of compressor do to low sump superheat,
    liquid slugging do to thermostatic expansion valve or orifice flooding compressor,starving
    for refrigerant do to thermostatic expansion valve or orifice not supplying enough refrigerant to keep the compressor cool, or is the reversing valve shifting properly or electrical,such as bad defrost board, capacitor,relay or electric component or connection, etc.
    With multi-compressor failures until you determine the cause and fix it you will keep having this problem
    And when a heat pump compressor fails if it’s a burn out, such as electric short or long running at high temperatures and pressures or low on refrigerant level not enough cooling back to the compressor, Causing the refrigerant to break down and create an acid. You need to check the oil in the bad compressor to see if there’s acid in it, then replace the compressor, reversing valve, accumulator (the oil and contaminents will accumulate here and you can‘t get it out), thermostatic expansion valve or orifice, liquid drier, suction line filter drier (if it’s on the lineset outside of the unit then you need to put it inside the unit as close to the compressor as possible).
    And after running the system for a couple of days, then the liquid drier and suction filter should be replaced again, depending on how bad the burnt out was or if there‘s acid still in the system you might need to replace them again.
    It’s hard to say who would be responsible but there’s something other than the compressor causing the problem and you need to find out what it is.
    Apr 20, 2009 | Heating & Cooling
    Lights on but no one's home.
    Let system sit for 15-30 mins. system cooled down and reset.
    Nov 15, 2008 | Whirlpool GEW9250 Electric Dryer
    New Dryer was purchased -- Tenant tells me he now requires higher voltage
    Hello Paulcolletti,
    I am not sure what you mean with your question.. Electric dryers typically use either 3 pole or 4 pole plugs that mate with the corresponding receptacle. If you already had an electric dryer there before, you need to make sure your power cord matches the receptacle. If it does not, most home goods stores ( like Home Depoit/ Lowes) and others carry the molded cord sets for that application and are reasonably easy to install. I fail to understand the low voltage versus high voltage comment as it pertains to a dryer. Please elaborate on this and maybe I can assist with a solution.. Good Luck...
    Oct 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
    Dryer dead
    you have no power to dryer ,,,, turn the breaker completely off, count to 30 and flip back on ,,, should work, if not replace the breaker
    Jul 03, 2008 | Whirlpool GEW9250P Electric Dryer
    Can't remove motor from dryer
    you need to pretty much disassemble the whole machine. the top cover comes off, the front panel with door comes off. the drum lifts out to access the motor as it is bolted to the floor.
    Nov 29, 2007 | Whirlpool LEQ9858P Electric Dryer
    Dryers Logo
    75 people viewed this question
    Top Dryers Experts
