Question about Poulan "Poulan" Push Mower
Starts fine but runs a too low a speed
Has plenty of gas and oil, i have checked the spark plug and air filter...but it just wont run at a fast speed.
are there any adjustments that can be done to the carborator that will increase engine speed?
  • 755 Answers
You probably have a partially blocked main jet inside your carb!
You need to pull the bowl of your carb and snake the main jet with a fine piece of wire *( a stripped twist tie is usually enough).
You might not have the type of carb that has the main jet underneath.
You need to run the model number on this unit and find the parts breakdown for the carb it has to locate the main jet.
Good luck and be careful.
Posted on Jul 07, 2010
  • goldsmithy May 03, 2011
    Also check the air filter. You'd be surprised how little it takes to plug the 5 or 6 holes of different sizes under the air-filter cartridge holder. Plugged air filter, something to check.
How do i stop the back firing and get it started
I had possibly the same problem with my lawn tractor about a month ago... I tried removing the carburetor and cleaning it, but I always ended up pushing debris into another area and creating new problems. Eventually I just bought a new carburetor, changed the oil (some gas had gotten into my oil thanks to the problems I had with my carburetor), cleaned the spark plug, emptied the oil filter and replaced it, checked the air filter ((no oil there, phew)... and it seems to be running fine after 3 engine hours (knock on wood).
My backstory is the lawn tractor was sitting in the garage with our car for two years and not used. I prepped it for long term storage, but failed to drain the carburetor of old gas, so the old gas gummed up the works (even with fuel stabilizer). When I did get it running (after changing everything listed above) a lot of smelly white smoke kept coming out, but as I let it idle in fast speed the engine strokes became more regular and the bouts of white smoke became fewer and shorter until the smoke stopped altogether.
Hopefully this helps!
Aug 10, 2014 | Craftsman Garden
Saw won't start without starting fluid.
Sounds like you have a compression problem. Starting fluid will fire at a much lower compression than a gas/oil mix so that's why it will start with it. When the motor is running you get a little more compression because the piston is coming up so fast. You should check the condition of your cylinder wall and piston & ring. If they are damaged at all you loose compression which directly affects starting and running power.
Mar 28, 2012 | McCulloch Garden
86, 1.6 liter, VW Golf, gas engine, 55KW, German Spec Car, Car mileage went from 24 to 5 MPG, I changed oil, oil filter, air filter, filled the tires to proper air pressure, changed the spark plugs and...
Check you're catalytic converter, Dont know how fast 40-60 KPH is but if it is near 40 miles per hour and has no power up hill that would be the first thing I would check. second would be Fuel pump... Hope this helps
Feb 14, 2011 | 2001 Volkswagen Golf
455 wont run
Make sure the muffler has not become plugged. Check the flywheel key as it may have sheared off for some reason causing the timing to be off, yet still generate sparks. Are the sparks blue and snappy? If not, check the ignition module gap to the flywheel magnets--use a thin business card for a gauge. A wide gap can cause weak spark. Hope this gets you running again!
Apr 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Mower was working fine then engine coughed and died. Plenty of fuel but can't get it started again. Any suggestions?
Ckeck the spark plug cable and make sure it is tight on the plug. You did not say what kind of mower but some have low oil shutdowns. Make sure the oil is up to the full mark. If neither of these items solve the problem check the spark. If there is good spark remove the air cleaner and squirt some gas into the carbburator and try to start. If it runs then dies you know it is a fuel problem.
Dec 03, 2009 | Garden
SPUTTERING WHEN HOLDING 50-60 MPH
Since it ran fine before you "fixed" it, go back over the things you changed. Put the old spark plugs back in it. Double check all spark plug wires and ignition connections. Put the bike in a dark area and run it at night, can you see any arcing anywhere?
Jul 01, 2009 | 2004 Honda VT 1100 C Shadow Spirit
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Engine won't start
in the engine.
1. you may be low in oil
2. poor electric flow. (spark plugs, high tension wires, etc)
3. bad compression
4. bad fuel-air mix
have a mechanic check.
hope it helps.
Aug 05, 2008 | 1994 Honda Accord
Poulan "Poulan" Push Mower Logo
618 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
