Question about Omega Rear Drive Wheel Snapper Mowers
Snapper that will not start. Just clicks
I have a Snapper that will not start. The solenoid just clicks when you turn the ignition. I can take a jumper cable and connect the positive post to the starter and it starts fine. When you jump the 2 posts on the solenoid, nothing happens. I have replaced the solenoid and it doesn't help. I have disconnected and/or bypassed the safety switches on the shifter and the deck to no avail. I have checked all of the ignition wires and cannot find anywhere that it is shorting out. The model number of the mower is 33128bde, although the engine on it is not the original engine. It was replaced with a B&S 11hp 2 years ago.
  • Don King Jul 07, 2010
    I should have mentioned that I started with the battery. I had replaced it at the beginning of the spring and I took it back where I bought it from and they tested it and found it was putting out almost 400 CCA (rated at 300 CCA). I am jumping from that battery to the starter post, so I'm sure it's not the battery. I will check the post on the starter and make sure it is secure.
  • 760 Answers
If it starts with the key when you jump it then it sounds like you have a bad or dirty connection in your battery cable or your battery is just too low. You didn't indicate where you were connecting your jumper cable, from the tractor battery or from another source. It could also be in your ground wire (but not if you only have to use one jumper cable). Remove the negative from you battery. Remove terminal from starter, and clean and be sure terminal is tight on the wire. Remove + cable from battery and clean. Remove ground terminal from engine, clean that connection. Check that the starter is firmly bolted to the engine.
Posted on Jul 07, 2010
  • Tom W Jul 08, 2010
    Ok, so you are only jumping with the positive cable from teh battery to the Starter terminal? (not the solonoid) And it starts. This indicates the starter is grounded, and the battery is grounded, and the starter is ok. You incicated you replaced the solonoid. Is it exactly the same as the one you had originally. Most B&S would use an internally grounded solonoid.(sometimes called a 3 pole) In other words, the negative would be supplied to the solonoid coil from the mounting to the engine block. The positive would be supplied through start switch, through safety switches, to the small temminal on the solonoid. It wouldn't click if it weren't grounded. If you bought a ungrounded version it would have 2 small terminals, and one whould have to be grounded. If you have a voltage tester. Test the voltage at the incoming terminal on the solenoid. (+ on terminal - on ground or -battery post) You should have at least 12V. Now while you watch the meter, hit the key. If this voltage drops off, then you have either a bad connection, or a bad battery cable. Sometimes the terminals on the ends of these cables get corroded. Have you tried clamping the jumper cable on the incoming side of the solonoid, and to the battery and then trying the key?
Snapper series 23 Elec start No click, new batt, starter ok, fuse ok What's next? Cant find solenoidO
if the battery and starter are good. i would check connections to be sure they are clean and tight. the solenoid should be under the seat. with the battery. see if you can jump the two posts. if you can the solenoid is probably bad take off and replace.
Apr 15, 2018 | Garden
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
05 dyna starter solenoid clicking, won't start or turn over.
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2013 | Harley Davidson XLH Sportster 883...
Ihave a vanguard 20 hp v twin on my snapper mower you turn the key and get like a kluk sounds like its coming from starter
Does it do it every time? First try and turn your engine by hand counter clockwise and try to start..sometimes the engine stops on a compression stroke and Is Under too much pressure for the initial start,..happened to my cub cadet laast week...,,if it turns and still gets a click...test or charge your battery..if it is ok you either have a bad solenoid or starter...first find the solenoid and croosing the two big post..it should spin the engine..if it spins it is your solenoid if not the starter is bad...not a hard job for either...both can be purchased at your local mower place...giid luck
Oct 24, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Engine will not start
Try taping on the starter while you are turning they key. The starter may be bad or drawing to much power. If the engine doesn't roll over use a voltmeter to check and see the ansers to these questions. Is power at the starter, is the solenoid good is it providing power to the starter, is the key ignition providing power to the solenoid
Oct 17, 2012 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Apr 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Snapper Hi-Vac riding mower that won't start with starter
You may need a 300cca battery, an ignition switch or a solenoid to get things going again. I also would check to make sure the starter gear has not locked in the flywheel teeth; it will burn up the starter. You should be able to go to the snapper website and put your model of mower in and find the parts and diagrams you need.
Good Day.
Oct 26, 2009 | Garden
WHEN I TURN THE KEY ON MY SNAPPER HYDRO IT CLICKS IN THE SOLENOID BUT WON'T TURN STARTER . NEW BATTERY AND SOLENOID BUT IT WON'T START.
If the battery is good and fully charged, it should turn over. If you have a pull rope as well as the starter, make sure the engine will rotate. If not, you can do the same thing by placing your hand on the air vent screen on top and twisting the air screen. If the starter was hung up, usually the solenoid won't click. Have your battery tested, make sure that it is fully charged. Although unlikely, the solenoid could be bad. I'm betting it's the battery charge.
Best regards, --W/D--
Jul 19, 2009 | Garden
Omega Rear Drive Wheel Snapper Mowers Logo
2,252 people viewed this question
Top Omega Garden Experts
cwradio73
Rodney Carroll
Level 1 Expert
randy yarpos
randy yarpos
Are you an Omega Garden Expert? Answer questions, earn points and help others
