Question about Goodman Heating & Cooling
A/C not coming on. The thermostat is set properly to cool, the temp to 67. However, on the interior fan runs and it does blow cool air but seem weak. I went outside to the A/C unit, and nothing is moving. I checked the circuit breaker and the exterior fuse box, but nether are tripped. The A/C unit is a Goodman SSX 16 series.
  • 677 Answers
You can use this link.
(inspectapedia.com/aircond/aircond1123.htm).
Hope it helps.
Posted on Jul 06, 2010
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
We do not run our a/c unit during the day so in the evening I turn it on and it seems like it takes forever for the inside of the house to cool down. This is an older model carrier and was in the home when...
Take a look at the condensor outside. With the unit running even on a cool day, the condensor fan (outside) should be blowing hot air. The air temp coming out of the register should be 20 degrees cooler yhan the coils in the house.. This is a reverse way to chk the evaporator temp for proper cooling. Now, the wire could be a problem if it is coming from the thermostat. Take notice of the outside unit is being controlled by the thermostat by having someone go from off to cool on the T-stst. If everything is working but the discharge air is warm your unit may need a charge. If I haven't confused both of us, I'll watch for you reply -Ned
Jul 06, 2011 | Heating & Cooling
I have hooked up all the wires and batteries correctly but the system is still blowing out nothing but cold air and the thermostat is a newly installed system
Check wiring done correctly.
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Helpful?
Jan 04, 2011 | Heating & Cooling
2003 Protege 5 overheating on long runs (> 20 min). Overheated today while driving at interstate speeds for > 15 min. Lost the coolant. Refilled with coolant. Return drive maintained normal engine...
Sounds like you have coolant leak if you are loosing coolant or a bad thermostat. I would replace the thermostat, they run about $10. The other fan is an aux fan and will only run when the a/c unit is on.
Mar 01, 2010 | 2003 Mazda Protege
A/c does not cool properly in the summer. Temp
YOU probably need to recharge the refrigerant there may be air in the lines and its almost empty. REMEMBER after filling the system with the correct refrigerant YOU MUST DISCONNECT THE NEG BATTERY CABLE FOR 1 MINUTE THEN HOOK IT BACK UP or the compressor will not turn on..
Jan 19, 2010 | 2008 Cadillac Srx
Window unit air conditioner kicks in only when its really hot out
I would consider replacing the t'stat if it does not seem to cycle at the desired temps. Also, the outside air allows fresh air to be introduced into the conditioned space but it will also effect, to a degree, the units ability to cool the conditioned space. Once you get the unit running, try it with the baffle on and closed and see which one you like. Remember, the outside air has and add humidity and can make it seem hotter than it really is in the room.
May 21, 2009 | Whirlpool Electronic Window Air...
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
98 Civic with non-functioning cooling fan
bad thermostat or worse a plugged heater core or bad summer/winter diverter valve. look for bad thermostat.
Dec 08, 2008 | 1998 Honda Civic
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
21 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
