Question about Canon MultiPASS MP370 All-In-One InkJet Printer
Check printer and registeration failed ink tank near full searal no. udb03330 canon multipass mp370
  • bessie hargett Jul 06, 2010
    great it's printing i thank yoy so much [ thank jesus for having excastion skills thanks again iwould give you a hug if i could.
  • Canon Master
  • 3,083 Answers
I think you're talking about this problem, and a tech on this website has the solution. Here it is:
check printer and registeration failed - 60c33c2.jpg drifterK
Rank: Wiz canon.gif Expert
Rating: 84%, 769 votes
this is the sequence that worked, and do not worry about the pad, it is a sponge that you can take it out gently yourself, wash it and put it back, no soap or squiz it. do not need to open the printer to do it, can take it out from where you replace the ink tanks.
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart. Good luck, and hope this helps.
Posted on Jul 06, 2010
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
What does Waste Ink nearly full mean? Canon MP370
If you peel enough apples, and throw the "waste" apple-peel into the basket, eventually the basket gets nearly full, and must be emptied.
Similarly, if you print enough pages, some of the ink becomes "waste",
and that "waste-ink" goes into a small sponge-and-bucket apparatus.
So, take the printer to a qualified technician, and get the printer serviced.
Nov 23, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Error ###345
The ink cartridges are
not installed
or a non-supported ink
cartridge is
installedi
or the ink cartridges are
not installed
Check if supported ink
tank(s) is installed, and
re-install them properly,
and then close the
scanning unit.
Oct 11, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
I had the problem of "waste tank nearly full"
I used the Reset Procedure Theo Vreven had posted.N.H.
Aug 21, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Message "wasted ink tank near full" on Canon Multipass F80
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Error waste ink tank near full
This page gave me a solution, try it.
Let me know if worked for you as for me scoring this solution. Thanks
Jan 30, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
I have a canon multipass MP370 printer. I am having trouble changing the ink cartridge. They will not stop in place where I can remove and replace.
Directions are here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=9527
If the thing isn't stopping as it's supposed to after you open it up, you may have a faulty sensor. This is a $150 new printer. If opening it -fully-, pushing back gently but firmly, still doesn't trigger the thing into thinking it's ready for a new ink tank, try yanking the power cable. You can generally also push the carriage, the carrier with the ink tanks, by hand without causing damage. Don't use too much force -- but it should move over about as difficult as a big dictionary across a table.
Dec 05, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
1) Enter SERVICE MODE.
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
3) Select [8] PRINTER TEST
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
5) Select 0. [INK COUNT].
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
(returning to the state of 3)),
and then press the [ON/OFF]
key.
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Theo
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
old marine
old marine
