Question about RCA R52WM24 52" HDTV Projection Television
I have a model #D52W15 that suddenly cuts off after 5 seconds
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be an issue with the power supply board of the TV however, please post a comment with the no# of times it blinks red/green on the front of the TV so that I can assist you further.
Thanks
Rylee
Posted on Jul 06, 2010
  • 8 more comments
  • Norman G Johnson III Jul 06, 2010
    The screen and sound comes up, but the screen color is mostly blue with fine squiggly horizontal lines across it. Then it becomes a brighter blue and turns off...then attempts to start one more time and completely turns off.
  • Rylee Smith
    Rylee Smith Jul 06, 2010
    This issue is caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Please also check the convergence board for cracked solder. If you want to do the repair yourself there are repair kits available which includes instructions on how to replace them.
    Can you tell me where the IC is located on this particular unit?
  • Rylee Smith
    Please check this picture:
  • Norman G Johnson III Jul 07, 2010
    Can you help me to locate the convergence IC on this unit?
    Thank you so much
  • Rylee Smith
    Rylee Smith Jul 07, 2010
    Please do accept the solution if the issue is
    resolved or post a comment for further assistance.
    Thanks
    Rylee
    This doesn't look familiar. Is this a photo of the model I mentioned with chasis #CTA221?
    Can you please reply to my last request? I am not a repair tech, but have repaired numerous electronic devices. I just need to be sure of what I'm replacing. Can you help?
  • Rylee Smith
    Sorry, missed your last post please check this picture:
My RCA D52W15 52 in. is not turning on. Please help!
Yes, it is not a good set and the situation you indicate means a short exists and the set is following the 3 strikes rule it has--it will attempt to come on 3 times and then go into shutdown.
Apr 03, 2012 | Televison & Video
I have a brand new set of Oster A5 model #78005 clippers. We own two large dogs--we cliipped the first one and it worked beautifully--we were about half finished with the second one and all of a sudden...
I'm sorry if this sounds academic, but regardless of whether or not the problem lies with the clipper or the blade set itself, since it is brand new, return it to the seller.
Apr 09, 2011 | Oster Golden A5 2-Speed Universal Motor...
RCA D52w15 will not turn on, flashes three times.
Replace you flyback transformer and Horizontal Output Transistor
Sep 28, 2009 | RCA HD52W59 HDTV Projection Television
RCA D52W15. Set's ON light will come on for about 10 seconds only
On Deflection board CK cp150 2200uf 16v if it is puffed up on top it is BAD there is 2 more capacitors you need to change out as well 220uf 35v in same circuit, resolder all pins on FBT flyback Transfomer.Also Ck second Ribbon connector make sure it is in correctly this ribbon can also cause set not to come on.
Aug 08, 2009 | RCA Televison & Video
D52w15 comes on then shuts off
Hi, thank you for visit fix ya.
This is a common problem on this kind tv.
Replace capacitors on power supply.
22000 uf 16V and 220uf 16 V; upgrade to 35V.
For parts, go to:
http://www.encompassparts.com/
Any question I will be here.
Thank you
Jul 28, 2009 | RCA D52W15 TV
Tv problems
There are some capacitors on the power/HV deflection board that usually blow. You can actually see that they have vented on the top. Cp150 is the most common to go.
Jan 07, 2009 | Televison & Video
Rca hd tv d52w15
that model is famous for having bad flybacks. fortunately they arent exspensive and there easy to replace. you can get a new replacement at the following link for less than 50 bucks and they give free instructions on how to install it properly.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch hdtv model D52W15
Blue CRT has shorts that causing the set to go into protective shutdown.
May 01, 2008 | RCA D52W15 TV
Rca d52w15
Possible short and safety is keeping the set from burning up. A service man should be able to find the short hopefully in a small amount of time.
Nov 05, 2007 | RCA D52W15 TV
Rca hd model #d52w15
That flashing means that the sweep power supply didnt start up along with the main power supply. It could be a shorted horizontal output transistor or a bad flyback transformer. Youll need a service manual to scope out the horizontal drive and see why itsnot starting up or staying on. if your not a servicer then there are no real user serviceable parts inside so contact your local AUTHORIZED servicer as they will have all the right service manuals as well as acess to all the proper parts. Not that an unauthorized shop is a bad thing its just they the unauthorized usually are not aware of troubles that rca sends there peeps. Good Luck
May 28, 2006 | RCA D52W15 TV
RCA R52WM24 52" HDTV Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
