Question about McCulloch 26cc Gas Backpack Blower Dual Jet Engine
Hello, i am just trying to find out if there is
Hello, i am just trying to find out if there is suppose to be fuel filters on the end of the gas lines inside the tank of my mcculloch leaf blower that was trashed at the dump that i got running so , i dont know what year it is but looks to me like there should be filters. thanks for any help, ken
    President:
  • 1,851 Answers
These units do not come with furl filters but you can add them.
Posted on Jul 06, 2010
What is the filter like piece in the gas container of Homelite trimmer? Is it supposed to be in there?
There are two lines that come out of the gas reservoir. One of these is the gas intake line. The filter is on the end inside the tank to keep trash out of the carburation system. If the filter is just loose inside the tank you might repair it with a gas line kit that has the filter on the end of the new replacement. However, you might see if the filter just slipped off the end of the intake line. Possibly it could be put back on. If this is the case, pull the line out through the gas cap opening after you have released it from the metal connection just above the tank.
Sep 24, 2014 | Garden
Craftsman Gas Powered Blower Mode 358.794772: Fuel lines broken and need replacement. Have new parts from Sears. One fuel line goes to the carb and connects to the fuel filter inside the fuel tank The...
A special fuel filter must be on the end of the fuel lines going into the tank, the line should be long enough for the filter to move around by gravity to stay in the fuel as the tank empties.
Sep 13, 2013 | managemylife.com
I have a Craftsman Weedwacker 25cc 358.791030 that won't start. Primer bulb is not getting gas. Gas line is connected to the filter resting at the bottom of the gas tank. The line for the primer bulb...
that line should be longer, it contains the filter which is the pick up, and should rest inside the tank fully,, see if its possible to pull that line farther into the tank, its not going to start until the primer bulb fills
Jul 24, 2011 | Craftsman Convertible 25cc. Gas Line...
Looked in gas tank, filter was free with nothing attached.
The filter is part of the clunk valve which is supposed to keep your fuel supply line submerged in the deepest part of your gas supply. Haul out the filter and the end of your gas line and reunite them.
Mar 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where is the in-line fuel filter?
according to autozone.com: Under vehicle, passenger side, below seating area, front of fuel tank, mounted on frame in fuel line
Sep 27, 2010 | 1995 Geo Tracker
Where is the fuel filter located, ona 99 jeep grand cherokee?
There are 2 filters.
  1. One is on the end of the pickup tube inside of the gas tank.
  2. The second is in-line, above the front edge of the gas tank, inboard of the frame member. It is part of the fuel regulator/filter assembly.
Here's a diagram:
http://www.wjjeeps.com/misc/fuel_filter_wj.jpg
Take care.
Jul 24, 2010 | 1999 Jeep Grand Cherokee
Fuel filter installation
Hello there:
assuming that thisiswhat youare loking for here Ford Explorer Fuel Filter - Hastings Product Description: HASTINGS FUEL FILTER -- OEM Direct Fit Replacement In-Line Fuel Filter, 3 1/8 O.D., 5/16 Inlet, 5/16 Outlet, 6 25/32Length, Replaces Ford F0TZ-9155-B; Baldwin BF1166,
  • 1991-1998: Eddie Bauer; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1991-1998: Sport; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1991-1998: XL; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1991-1998: XLT; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1993-1998: Limited; 6Cyl 4.0L GAS, FI, VIN "X";
ahg8018.jpg Ford Explorer Fuel Filter - Fram Product Description: FRAM IN-LINE GASOLINE FUEL FILTER -- 7.16" Height, 5/16 (Tube) I.D., 2.13" O.D., Features High Technology Filtration, Designed To Provide Optimum Balance Between Low Restriction And Required Efficiency, Comes With....
  • 1999-1999: XL; 6Cyl 4.0L GAS, FI, VIN "E";
  • 1999-1999: XL; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1999-2000: Eddie Bauer; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1999-2000: Sport; 6Cyl 4.0L GAS, FI, VIN "X";
  • 1999-2000: XLS; 6Cyl 4.0L GAS, FI, VIN "X";
are several filters that willfit your vehical
Nov 22, 2009 | 1996 Ford Explorer
I changed fuel filter, fuel pump, runs go for a minute then acts as though its running out of gas again boggind down in park
Try changing the fuel filter but use the repair manual to depressurize the fuel system before attempting the replacement,gas in the eyes is dangerous and painful. I suppose you could let the car sit for 4-5 hours and it will be safe to change out the filter.
Jul 13, 2009 | 2000 Ford Focus
POOR GAS MILEAGE
Have you changed the fuel filter? I know it sounds weird but a plugged filter will make a truck use more gas. The computer tries to compensate for less fuel by commanding the injectors to open longer. Also a plugged filter will cause excess back pressure on the fuel pump making it loud.. Good Luck.
May 29, 2009 | 2001 GMC Sonoma Extended Cab
Fuel injector 450 xc
fills with gas then stops. The Bike doesn't start and the injector just doesn't make anymore noise isn't it suppose to be going continuously? if so then wat can i do to fix this problem ?,The fuel pump primes for a few seconds and then shuts off until the bike starts. What you are describing sounds normal. If your filter is filling with gas you may have a dirty fuel filter, or the orings in the quick disconnect may be blocking the fuel on either side of the tank. One of my friends had a oring blocking the return line and it ended up taking out his pump. Make sure you have a good stream of fuel returning to the tank, if so there is no blockage. ,,,
Nov 10, 2008 | 2007 ATK 450 Xc
McCulloch 26cc Gas Backpack Blower Dual Jet Engine Logo
159 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
