Question about Lands Phones
Phone modelSE445 one handset shows 'Warning Batt' permanently even after new batteries are fitted
  • tonyleydon Apr 18, 2008
    I did that whwn I bought the phone several weeks ago
    phopne works OK when new batteries are fitted, for about 6 hours then 'Warning Batt' signal reappears
    Genius:
  • 2,035 Answers
The handset must be charged for at least 24 hours before using it for the first time. Use on this link to get the manual : http://www.p4c.philips.com/files/s/se4451s_05/se4451s_05_dfu_eng.pdf#search='Warning%20Batt'
Posted on Apr 18, 2008
  • Anand Kumar
    Anand Kumar Apr 18, 2008
    Try to set to factory setting back on the phone.
    President:
  • 1,944 Answers
Try leaving the battery out overnight.
  • 19,396 Answers
There may be a problem with battery contacts in battery slot
  • Ginko
    Ginko Apr 18, 2008
    If your new battery it is not faulty, then It is possible that you have
    oxyde on battery contacts, or a broken battery contact inside your phone.
    In this last case the phone will shut down if removed from charger.
    You need to use a multimeter to test power from battery
    recharge slot contactst on phone if there is power with right voltage,
    then new battery is faulty, if there is no power then is a broken
    contact inside phone.
  • Ginko
    Ginko Apr 18, 2008
    I am glad you fixed it.
    Thanks for using Fixya.
I bought a base and one extension phone - no problem - bought another extension phone and it will not register
The new phone must fit into the base cradle for registering to even be attempted. You gave no model numbers, it is likely your newest handset is not compatible with the rest of your system... but we can sometimes "cheat". If the new handset is displaying "To register, place on base..." but it simply does not fit -- try removing the battery cover and see if wiggling the handset will allow the "charging" lamp to come on: then wait to see if it will register. You can find the base model number on a small sticker on the bottom of the base, the handset model numbers are on stickers under the battery.
Apr 09, 2016 | Vtech Cordless Phone Battery for 2429,...
Panasonic KX-7431 Call limited to 60 minutes
A year later. I looked at the manual for your model phone and didn't see any reference to adjusting the time a handset can be in use before disconnecting. Does the phone give any kind of warning before it disconnects? My suggestion is even if the battery is well charged that might be the limit of the battery. If not the battery and you get a warning that the handset is about to disconnect you might try pressing and releasing the talk button to reset the handset timer if there is one before the 60 min. has expired. Doing this shouldn't disconnect your party.
Jan 09, 2014 | Panasonic Lands Phones
The phone is dead but the machine still answer calls
Make sure the battery is inserted correctly in the cordless handset and that it is left on the charging cradle to fully charge overnight.
If the battery still does not power the phone even after charging, then the battery may be permanently depleted. Try buying a new battery for the unit. Be sure to fully charge the new battery as well before using.
Good luck.
Apr 17, 2011 | Uniden EXA 7950 Cordless Phone
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
Aug 05, 2009 | Vtech mi6896 Trio Cordless Phone
Unide TRU9485-2 handset goes dead after answering. new batt.-same
clean contacts with qtip and rubbing alcohol and bend out!!!! :)
Jul 07, 2009 | Uniden Cordless Phone
2 of my 4 vtech handsets keep giving me a 'check battery warning'
Try to reset the handset from handset menu, maybe the eeprom setting for low battery warning threshold have been ereased . Also check ,if the battery is the oregional battery for the phone.
Jan 21, 2009 | Vtech Lands Phones
We have BT Studio 1100 with three handsets. From working well, they all became dead. We have changed the batteries. The phone line is working, and there is electricity reaching all the cradles which...
I have the same phone but with two handsets. Incoming calls only ring on the base and I cannot answer or make calls as the handset is permanently flassing "base 1". I have tried disconnecting and reconnecting. Also tried to restart setup but this is showing unavailable although I can still access the phone menus.
Jul 01, 2008 | Lands Phones
Philips cordless phone DECT 122
Can you guy try to reset handset from menu.
Jul 26, 2007 | Philips DECT 2252S Cordless Phone
Recharging phone constant beep
When misplaced in the charger the xg2200 beeps, are you sure the phone is placed correctly? please let me know. Good Luck
Mar 01, 2006 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
156 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
