Question about Video Game Consoles & Games
I am trying to find a drawing pad for the Sega Pico game system. Do you know where I can find one?
  • 107 Answers
Your best bet will be Ebay. There are a lot of older game system peripherals to be found.
Posted on Apr 18, 2008
How to fix a stuck button on game gear
This is an easy fix. Open the Game Gear by removing the back panel. Take off the front panel, and the buttons and pads will come up. Remove the pads and buttons and clean the pads, buttons with alcohol, to remove the dirt and gunk around the buttons and pads . When finished replace the cover. Test the system. If the pads do not respond to the game, the pads may be worn down and may need replacing. There is a website called Ifixit that has the parts for the Game Gear. Go to ifixit.com to get the parts. Or go to Sega.com for help. Also call 1-800-872-7342. This is the number for SEGA . Hope this information helps.
Jan 10, 2014 | Sega Game Gear Console
Control pad
Control pad's are generally all or nothing devices, they either work or they're dead. However with a console of this vintage there are a few things that can cause this kind of issue and therefor a couple things you can do to try and resolve it. 1: Clean the serial ports and plugs (the ports and plugs that connect the pads to the console) with an air duster. Air dusters are cans of compressed air with a long nozzle and are available from most computer, electronics and hardware stores. Clean both serial ports even if you're only using one. 2: if cleaning doesn't work try unplugging the power cable, removing the console's casing and touching a hot soldering iron to the base of each of the pins that connect the serial ports to the PCB (Printed Circuit Board) in tern to re-solder them without using any extra solder, if you find that you do need more solder be sparing. You can see a pictorial guide to disassembling a Sega Genesis here www.takeitapart.net/archives/sega-genesis/ click the pictures to see a larger image. Lastly if you know anyone else who's in to retro-gaming swap a control pad with them to see if your pad works on there Sega Genesis and there pad works on yours. If you find the pad actually is dead it's not the end of the world, there are a few around on popular auction sites, retro gaming sites and specialist game stores pretty cheaply.
Aug 23, 2007 | Sega Genesis Console
The down button on my Sega Master System controllers won't work when they are plugged into the first controller port (Fine on the second). I have already taken apart the system and tried to clean up...
Hey there.
In your case, there is only one real solution: get another controller. You will save both time and money, and you will know that you'll have a working controller. Chances are you will not ever be able to fix that problem, even with soldering.
You could start by browsing ebay:
http://video-games.shop.ebay.com/System-Accessories-/54968/i.html?rt=nc&Platform=Sega%2520Master%2520System&_nkw=sega%20controller&_catref=1&_dmpt=Video_Games_Accessories&_fln=1&_ssov=1&_trksid=p3286.c0.m282
If you really want to try to spend some time repairing it, that video could help you understand the controller a lot more:
http://www.youtube.com/watch?v=QJ02G-pSNa0
Hope I helped you!
Jul 08, 2011 | Sega Master System Console
I recently found my old sega megadrive/mega-cd and I've dusted it off and tried to reconnect it but have found i'm missing the cable which links it to the tv. According to the instruction manual I'm...
I searched and Sega themselves do not deal with older systems,however here is a phone number to the place that can probably help.They are contracted for the older systems I guess.It is called an RF connector or RF cable too.(714)836-4981.I don't see your system on the list on the link but it wasn't on Sega.com either.
http://sega-parts.com/ is the older systems link.
Sega's main number is 1-800-USA-SEGA but good luck trying to actually talk to someone.No surprise there huh?
Good luck and game on!
Jul 26, 2010 | Sega Genesis 2 Console
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Jul 26, 2010 | Sega Master System Console
Sega not working no matter what.
Does it power up,,if its just not playing the games,, take some quetips and dip them in alcohol,,use it to clean inside the genesis where the games go in and clean the games with it,, if you have the sega cd addon system ,,also clean the place on the side where u connect the sega cd,, hope this helps,,i have 4 or 5 sega genesis,, and the sega cd system,,,thanks
Oct 05, 2008 | Sega Genesis Console
Directional Pad
honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Aug 20, 2008 | Sega Master System Console
Controller port 1
i had the same prob a few years ago when i had my frist one probly dry jonits
Aug 04, 2008 | Sega Genesis 2 Console
Sega master system
You need an RF Switch. Any kind will do. Sega model 3035 came with your console. Sega model 1603 or Nintendo NES-003 will also work. The RCA plug goes in the back of the console and the lead that looks like cable tv goes on the tv. If your tv does not have the right connection you can purchase an a/v cable that will work.
Oct 20, 2007 | Sega Master System Console
Video Game Consoles & Games Logo
56 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
