Question about Microsoft Windows Vista Ultimate Edition
How to make an external operating system? - Microsoft Windows Vista Ultimate Edition
  • 304 Answers
You may install the Operating System on any External Storage Device by following the detailed steps mentioned in the link below:
http://www.ehow.com/how_4853479_operating-system-external-hard-drive.html
Hope this helps.
Posted on Jul 06, 2010
Power but no display
THE EXTERNAL WORKS ? IF YES MAYBE IS YOUR INVERTER DISPLAY DEFECTIVE. IF NOT YOU HAVE PROBLEM WITH YOUR CHIP GRAPHICS ON MAINBOARD AND NEED REPLACEMENT
Oct 21, 2013 | NEC Versa Computers & Internet
Tip
How to Install an Operating System on an External USB Hard Drive:
You may have an external hard drive you want to use for more than just document backup.
In this situation, you can install an operating system onto your external hard drive. By doing so, you will be able to run your external hard drive as a fully functional operating system.
If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup.
1) Plug your external Hard Drive into your Computer using the USB cable. Insert the installation disk for your Operating System into the CD/DVD Drive. Turn on or restart your Computer.
2) Boot from the installation disk. You may have to press a key once prompted to boot from the installation disk.
3) Accept the license terms and conditions. Read through these carefully if you wish to understand your legal rights as a user. If you disagree with these terms and conditions, you may want to purchase a different Operating System.
4) Choose your destination drive. Your external Hard Drive will likely be the E: or F: drive. By default, the C: will represent your main Hard Drive and the D: will usually represent your CD/DVD Drive.
5) Begin the installation. Your external Hard Drive will install the Operating System. You will now be able to run that Operating System off of your external hard drive.
Hope this helps.
on Sep 03, 2010 | Computers & Internet
I turned off my computer all of a sudden before it saved settings.the next time i turned on my computer, all icons were not there and windows installer is not working. micro soft office is also not...
Maybe you can try this.....IF you have Windows 7 Operating System...AND If you have previously made an "External Start-up /Repair Disk" for your PC....While the PC is running, insert it into your external CD-ROM disk drive, then shut down/restart your PC. I have had to use this external Startup/Repair Disk several times with my Windows 7 system when it had problems...or the PC just would not boot up....and it corrected my Win7 operating system start-up system / software problems successfully. Hope fully your PC Bios "setup" is setup to go look at the external drive during startup mode to see if their is a "boot" disk in there. Your PC Manual should tell you how to change the PC Bios system Setup so that when you start it up, the PC will look at the external CD-ROM drive for the presence of a boot-up start program like the Windows External Start/Repair disk.
Hope this helps. Gary
This Startup/Repair Disk is created by the PC User after early operatation the PC operating system... based on instruction manual from the PC maker. If you have Windows 7 and did NOT make this external startup/repair CD-ROM disk...I recommend you do that ASAP...and try it out.
Oct 15, 2011 | HP Computers & Internet
I have Iomega external desk hard drive 160gb silver edition series I install windows 7 pro. When I tried to install the software it would not install. message states that this product does not work with...
Hi jtenu2,
The reason why you're getting the error message "product does not work with this operating system", is because the software is not compatible with your operating system. The easiest way to solve this error is to check if you're running a 32 or 64 bit operating system. Just right click on my computer then select properties and it will show you the details of your system. If you're using a 64 bit operating system you also need to install a 64 bit software on it.
Hope it helps.
Thank you for using FixYa.
Apr 05, 2011 | Iomega Silver Series External 250GB...
How to install os in usb hard disk
First plug your external hard drive "disk" into your computer using your USB cable. Then insert your CD/DVD in your CD/DVD Drive "D, or E, or F" that are define in your system and turn off your computer and On your System "computer". Then boot form the installation disk. Begin the installation so that the hard drive will install the operating system. Then accept the license terms and conditions. Then choose your destination drive."By default, the C: will represent your main hard drive and the D: will usually represent your CD/DVD drive. So your external hard drive will be the E: or F: drive. "And you will now able to run that operating system."
N.B: "You will be able to run your external hard drive as a fully functional operating system. If your primary hard drive ever crashes, you will have a backup option unavailable to those who simply use their external hard drives as file and document backup."
All the Best!
Oct 18, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Can i use an external hard drive to run an operating system (XP)
Yes. You can run an OS from an external hard drive. You have to install the OS to the External hard drive and will have to boot from the USB. I have tried that for Fedora Linux OS but not for XP. Basically all Operating systems boots up in the same manner. So definitely, its possible with windows XP also.
Thanks
Sherbaz
Sep 21, 2010 | Acer Veriton 5500 PC Desktop
You may install an Operating System on any External Storage Device by following the detailed steps mentioned in the link below:
Hope this helps.
Jul 06, 2010 | Microsoft Computers & Internet
I bought a seagate 500 But I don't know how to put pictures on it
Yes. Its possible.
  • Step 1: Analyze the system requirements of the Windows operating system. Windows XP requires 1.5 gigabytes of free hard drive space. Windows Vista requires 20 gigabytes (for the Home Basic edition) or 50 gigabytes (for all other editions). The system requirements for older, outdated versions of the Windows operating system, such as Windows Me and Windows 98, can be found on the official Microsoft Windows Web site (link in the Resources section).
  • Step 2 :Connect the external hard drive to the computer with which you plan to use the hard drive. Use the hard drive's original cables included by the drive's manufacturer. It does not matter what connectivity standard you use. Windows will automatically detect the external hard drive.
  • Step 3: Click the Start menu in the lower left-hand corner of the PC screen and select My Computer.
  • Step 4: Right-click the icon for the external hard drive. Click Format from the pop-up menu. Format the external hard drive in the NTSF format.
  • Step 5: Insert the original Windows installation disk into your computer's CD-ROM drive. Close the Installation Wizard when it appears on the screen.
  • Step 6: Return to the My Computer window from Step 3. Write down the drive letters assigned to the CD-ROM drive and the drive of your external hard drive. For the sake of this article, we will use the example of D:\\ being the external hard drive and E:\\ being the CD-ROM drive. These are typically the letters assigned to CD-ROM and external drives in the Windows operating system.
  • Step 7: Click the Start menu button and select Run.
  • Step 8: Type "E:\I386\winnt32.exe /syspart:D: /tempdrive:D: /makelocalsource /noreboot" (without quotation marks) and click OK. This launches the Windows installer file on the Windows installation disk in drive E:\\ and commands it to install on the D:\\ drive (your external hard drive). The Windows Installer Wizard screen will appear. (Change the Drive Letter as in your Machine)
  • Step 9: Select the Full Install option in the Windows Installer Wizard. You will then be guided through the Windows installation disk. Follow the on-screen prompts to complete the installation. Depending on the speed of your computer's processor, this may take several hours. Be prepared to enter important information, such as your Windows registration key to register your copy of the Windows operating system. Do not close the installation window until the installation process is complete.
Please rate the answer if you feel that this solution solved your issue.
Thanks for contacting Fixya!
Step 10 Shut down the computer and disconnect the external hard drive. You can now use the external hard drive to boot up another computer using the installed copy of the Windows operating system.
Jun 29, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How can i save my project to external hard drive..? because when i'm trying to save it, there is a notification that my external hard drive can't modified. my external hard drive is just find with any...
Different operating systems use different file systems. Normally they can't use other ones than their own. To write on NTFS file system (Windows) a Mac needs a special program - get it from here http://www.macupdate.com/info.php/id/26288
Nov 27, 2009 | Computers & Internet
External dvd writer
You would be able to boot from the external drive but you will not be able to run an operating system from it. It would allow you to install another operating system if that is what you mean? If i understand you correctly though, you would like to say perhaps, have windows xp on your laptop and maybe run windows vista on your external? Maybe get to choose which one to run. This is not possible. Sorry. I hope this helps!
Dec 05, 2007 | NEC Versa FX Notebook
Microsoft Windows Vista Ultimate Edition Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
