Older hotpoint washer
Thought the timer was bad because when on put it on small load it just kept filling up till it overflowed.got new timer and now its setting is in the wrong spot on the face plate. for example when it is set to large load cotton it is washing. not filling up with water like it should can you help
  • 145 Answers
Sounds like a pressure switch problem not a timer. depending on the year and model they had alot of water level problems.
Posted on Apr 18, 2008
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
Water will not stop when I shut the washer off.
Possible that the inlet valve has failed and so does not cut off even after the power to the unit or the control unit has been disconnected.
Aug 03, 2012 | Kenmore Washing Machines
The water runs in the tub but never stops. Even if you put it on spin to run the water out. The water never stops till it runs over the top of the tub. Is that something in the main control timer that is...
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Maytag HAV2557 Top Load Washer
Elba WA50T54W1 water just overflowing not cutting of when full
water level pressure switch tube is clogged with lint or bladder in pressure switch is bad. disconnect power to washer open timer console look for a clear rubber hose disconnect fron switch and blow in tube a couple times reconnect tube and put unit on drain and spin for a second then retrying unit for water level fill put washer on small load water size and test if it continues to fill replace pressure switch...
Jan 23, 2011 | Washing Machines
The washer leaked water. It is about 8 yrs old and was working just fine til tonite. It didnt leak from the supply hoses or drain hose, I tipped it over and the outside of the drum was wet like it...
If it looks like the water overflowed then it could be a bad pressure switch the way to test it out is just fill it with water and set the washer on small load if it continues to put in water past the small load setting then you have a bad pressure switch
AST Appliance Repair in San Diego
Jan 17, 2011 | Roper RAS8445KQ Top Load Washer
Just fills with water
if all it does is fills with water it may be a bad timer or the motor has gone bad. turn it to spin cycle and turn it on you can check for voltage at the motor . if you have voltage then you have a bad motor if you have no voltage then you have a bad timer on your washer . if it just fills and fills till it is about to overflow then you have a bad water level switch or tube . just a few things to check
Oct 30, 2009 | Candy Washing Machines
HOTPOINT WASHER OVERFLOWS ON ALL CYCLES
This is most likely a damaged pipe going to the low pressure sensor. This sensor determines when to turn water off by the pressure built up in a tube. If there is a damaged pipe - it wil overflow.
Turn off and disconnect machine, then remove access pannel to inspect all small bore pipes for damage. Check pressure valve for correct operation.
If it leaks at times other than filling, and water level seems ok, then it could be a damaged top or bottom seal that needs identifying and replacing.
If it leaks constantly it could equally be a damaged rubber pipe between drum and pump.
You really need to remove an access pannel - and just observe operation without putting your fingers in thereto spot it.
Sep 08, 2009 | Hotpoint VBXR1090D Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
GE WJXR2080T2WW Washer Fills with water - then stops
older machine would have been easier to fix ..remove front ck small hose to tub left side remove hose and clean crud from end as much as possible if still overflowing replace water level control..new machine may be timer or lid switch not closing properly remove front to acess lid switch on right side
Jul 22, 2008 | Washing Machines
Overflow
If you unplug the machine and the water still comes in, you have a bad Water Inlet Valve. If when you turn the machine on at in overfills and you can stop the water by turning off the washer timer then you have one of a couple possible issues.
First, you pressure sensing tube could be clogged
Second, you just plain have a defective pressure sensing switch.
If you have anymore questions, feel free to comment back.
Thank you
Mar 26, 2008 | Hotpoint VBSR3100D Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
