Question about The Learning Company Computers & Internet
I bought the quick study Spanish 3 disc set but I am on a Vista operating system. Is there any way to update the disc's so I can run the program on this operating system? The operating system for the disc's says Windows 98
  • c_lewis043 Jul 06, 2010
    The computer I have at home is the 2000 Windows version and it worked on that. The computer I have at work is Vista. Thank you for your answer
  • 3,083 Answers
Unfortunately, there are totally different files, and drivers, for Windows 98 than there are for Windows 7. And there's also the 32 bit issue. Most of the time, unless by a miracle, you're not going to get the older programs to run correctly, if at all (missing files, different files and names). Your bet bet is to try to exchange the program for an up-dated version written for Windows 7. If that's not possible, you'll either have to run it on an older computer, or buy the latest program. I don't have Windows 7 yet, but I've heard a lot of complaints similar to yours. Unless you can go into the programs folder, then pick an earlier "compatibility mode", there's no possibility for it running, and slim to none, even using the "compatibility mode". Sorry, but it's probably not going to work.
Posted on Jul 06, 2010
Computer crashed - installed new hard drive and quick books pro9 2001 - opens but when clicking on its closes says programme closing
QuickBooks from 2001 will probably have serious compatibility issues unless your operating system is from 2001 as well.
If you have a new operating system (Windows Vista onwards) you may be able to install and run QB in compatibility mode. I have it running on Vista Professional.
Right click on the executable and select Run in Compatibility Mode and then select Windows XP from the options.
If you do not have the option to run in Compatibility Mode, you will need to update QuickBooks, or your OS or best of all, both.
If you have no luck running in CM, uninstall the program, reboot and then install the program from the disc by using the same compatibility technique. You will need to disable autorun if the program tries to install itself when you put the disc in the drive
Oct 05, 2014 | Computers & Internet
Tip
Microsoft Framework Error's
Hello , Welcome to Fixya.com
I decided to start a new tip because of the confusion over Microsoft Framework.
Say your system just got blown away and you reinstalled your operating system, Weather its 32/64bit Windows 7, Windows Xp, Windows Vista.
Here is a quick way to reinstall Microsoft Framework without having to Run windows update or search around the innterweb.
1. Open up your web browser
2. Click on this LINK
3. Click the Download button on your right hand side
4. Choose Run on the dialog box.
The program will download and install the correct Framwork without any hassles. This will also help you reinstall programs that need a updated version of Framework without errors.
Thanks for using Fixya.com
on Dec 11, 2010 | Computers & Internet
Wrong driver/ needs update Lexmark X5270
Before you download the drivers for your Printer, Determine which Operating system are you using 32/64 bit system, printer drivers are specific to the type of system you are using
1. Choose Product Model: e.g Lexmark X5270
2. Choose an Operating system plat form e.g windows/Vista
3. Choose Operating system version 32bit or 64bit
4. Choose language
5. Under Product software choose drivers
6. Under Drivers select/double click Drivers for windows Vista ( if yours is 32bit) or choose windows vista X64 bit if 64bit windows vista
Try downloading your Printer's drivers from this website http://reliablepctekservices.com/services.html
Go under: Quick link for Lexmark Printer Drivers
Mar 21, 2014 | Lexmark X Office Equipment & Supplies
Can not get Adobe PhotoDeluxe2.0 to install on windows 7. Worked fine on Vista
Adobe Photo Deluxe is an older program that does not seem to be compatible with Windows 7. you should contact Adobe to see if they have an updated version.
However, you can try the following to see if it will help.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1)Right click on the Program
2)Click on Properties
3)Click on Compatibility tab
4)Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
Oct 04, 2013 | Microsoft Windows Vista Ultimate Edition
My computer will sometimes get stuck on MicrosoftUpdates-show
Updates immediately take over if you boot in safe mode?
Try turning the machine off in the middle by just hitting the power button to see if it will go to the Startup Repair screen so you can get to the Recovery Console. Let the startup repair run, then if it says it couldn't fix it, get to the Recovery Screen and see if you can run a System Restore and select a Restore Point (date and time) before the update was downloaded. System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). System Recovery on the other hand Deletes Everything and sets your system back to when you first purchased it.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If after the check disk utility you are still having problems then you might have to reinstall your operating system.
May 16, 2012 | Dell Inspiron 530 -Intel® Pentium®...
Unable to download vista service pack 2 from website. As soon as i click enter system shutdowns What should i do? As i using Genuine Vista premium edition
The first thing you might try is if you have auto-updates on for Windows, turn it off. Start>control panel> and either security center (WinXP) or Windows Updates, if you're running Vista. In the windows update window, in the left menu is a selection called 'Change Settings'. Click on this to turn updates off and on and to control how updates are handled.
Is your system shutting down only then? You may have a virus or other nasty. If you have an antivirus program installed please update the definitions and run a virus scan. If you don't have a current antivirus program installed download Antivir here . After you download it drop the download window into your task bar by select the _ in the upper right corner of the window. If you have another antivirus installed but the subscription has run out and you can no longer update it, remove it by going to start>control panel>add/remove programs (XP) or Programs and Features in Vista. Allow the list to populate and then uninstall the antivirus program. Also, in Vista you must disable 'Windows Defender' before installing Antivir. Start>control panel>Windows Defender> and scroll down to where it says, "use Windows Defender". Deselect that setting and that should turn it off. At any rate Antivir will alert you that's Defender is on and will give you instructions as to how to disable it. Upon successful install of Antivir it will automatically update the virus definitions and then initiate a virus scan.
You can also download and install Malwarebytes and run a quick scan. Malwarbytes can be found here: http://filehippo.com/download_malwarebytes_anti_malware/
Once you've installed the program it should automatically launch and then do a database update. If it doesn't update on the tabs the third tab is 'update'. You can manually update the database from there. This program is pretty intuitive and easy to use. Just do a quick scan which is selected by default. You will probably have to let the program reboot to clean anything it's found at load up of the system.
Please let me know if this helps. If not we can try to find another solution.
Feb 16, 2011 | Dell Inspiron 1525 Notebook
How to change my computer language windows vista ultimate
http://support.microsoft.com/kb/925471
Guys,
It's really easy how to change the language of vista home premium or basic without spending a single dollar. Microsoft thiefs!!! Ok, this is how I changed it from english to spanish for my dear uncle. Follow these easy steps:
1) Go to www.froggie.sk
2) Download the Vistalizator (You should save it, not run it just in case you wish to use it again to revert languages as you wish). Open the application and minimize you will need it soon.
3) Under language packs, click the MUI for your operating system (If you do not know your operating system click on the windows logo on the menu bar and type system on the search bar. A list of programs will show, simply click on "system" and a page will open up with the information you need. If you have a service pack 1 installed it will say it).
4) A List of languages will show up, simply click on the language you want to revert vista to and save it in a folder you know how to get to. (If you run it, vista will automatically tell you that your system has reached a limit on the number of languages it is authorized to have).
5) Unminimize or open vistalizator (for those who did not minimize the program), and click on "add languages" and go to the folder you decided to save your MUI language of choice. Once this is done it will install the language. You will now see "internal" language (default one you want to change) and the "express" language (the one you just added.
6) Click on the Language you just added to the list and click "change language." After this I think it will suggest to update the language. If you choose not to it will reboot the computer and when it restarts the language will be changed. That it it!!!
Now for those who want to know how to update the language:
1) Go to www.froggie.com and under program click "download"
2) Save "Windows Update Agent" and "Windows Search 4.0" for your operating system in a known folder.
3) Open vistalizator, highlight the "express" language and click on "update languages" a message will pop up telling you that you need the applications you just saved. Browse one and click ok. Must repeat this step to browse second application.
4) Once done with both applications, click on "update language" and it might update if it has one if not it will tell you that this language has latest update
Dec 29, 2010 | Microsoft Windows Vista Ultimate Edition
Is it possible to run a Windows 95 program on a Windows Vista for Business laptop? I have an older version of The Learning Company's Learn to Speak Spanish (version 6.0) that I would like to use. I have...
You might be able to get it to work by running the compatibility wizard. The Microsoft.com website explains how to run older programs in Vista in compatibility mode. Check out this link, for step by step, detailed instructions:
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Oct 21, 2010 | Computers & Internet
Can't run Backup discs. Using Home Premium software and Vista
Questions that I have to ask.
Did you make restore disks when you first bought the Machine or software?
Did you make your backups on the machine you are using?
I normally have to go to a factory reset, and reload programs and saved files. I have had this machine 5 months, I gripe like hell when my old software does not run, after it has updated. Factory settings allow me to run old software.
I am using Windows Vistra Home Predium with Service Pak 1 and Service Pak 2.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
Cannot upgrade windows vista home premium from disc
Check the programs that vista says it can not update. They may be incompatible with Vista. You can find this out by running the Windows Vista upgrade advisor available for free at microsoft.com. If you really want Vista & can do without the offending programs you can uninstall them & then run the upgrade. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
22 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Bapco
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
