Question about Maxon HCB-10C CB Radio
I cant get the front off i got the back off but i can expose all of the internal components
I left my zte blade a430 outside in the rain for 2 days,i opened the back and dried it but the screen wont go on! can you help please?
From past experience on anything electronic, once the internal circuit is exposed to water, moisture etc.. and with the battery still attached, the corrosion sets in and pretty well destroys the components and connections one by one. Sorry, no miracle cure. Your only salvation would be if the device has a warranty for this kind of damage. Wish I could help you more.
Jan 07, 2016 | ZTE Cell Phones
Need to replace controller
Pull the drawer out and remove the plastic clips with plier (one on each side). Carefully remove the front cover and this will expose the front components of the drawer including the controller. Take a few photos to make sure you get everything back in the right way (especially the controller connectors).
Mar 31, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
Karoake will not put sound through speaker or microphone memorex mks8595
download your instr. manual from www.retrevo.com or www.manualslib.com
Amplifiers are assembled with many of the same components as other appliances, so fixing basic elements is similar. For example, cords may not consistently deliver electricity, switches and controllers can cause problems, and fuses may need to be replaced. Frequently, however, what the amplifier needs most is simply a thorough cleaning with some canned air and/or contact cleaner.
The first step in fixing internal parts in your amplifier is to open the unit up. Most amplifiers are encased in a two-piece housing--top-front and bottom-back.
audioamplifier3.jpg Besides fuses accessed from the back of the cabinet, many amplifiers include one or more internal fuses. Disassemble an amplifier:
  1. Make sure that the electrical cord is unplugged from the wall receptacle.
  2. Remove screws on the side, back, or bottom to separate the cover from the chassis.
  3. Slide the two halves apart to expose the internal components mounted on the chassis (lower frame).
  4. Inspect the internal end of the electrical cord for looseness or damage caused by being pulled (a common problem) and replace as needed.
  5. If there is no power, but the cord works, look for an internal fuse. Test the fuse and replace as needed.
  6. Use a can of compressed air to carefully blow away dust that is attracted to electronic components. If excessive, use a vacuum cleaner with a plastic tip (so delicate parts won't receive static electricity) to clean the inside of the unit.
  7. Use electrical contact cleaner to clean the input jacks and speaker terminals. If one of the input jacks is disconnected from the wires, either reconnect or resolder it.
Oct 01, 2012 | Televison & Video
My monitor went off, is there any other way to turn the desk top computer off other than disconnecting it? Gateway GT5676
The internal components of the computer are sensitive to electrostatic discharge (ESD). Damage to the motherboard, memory modules, and peripheral cards can occur if these parts are exposed to ESD. If you are familiar with and have a grounding strap, use it while handling any internal components. If you do not have a grounding strap, it is a good idea to touch the computer case anywhere on the bare metal prior to disconnecting the power cord.
Jul 22, 2012 | Computers & Internet
Wher is the pump on a front loader
It depends upon the model number, but MOST front loader washers have a drain pump located directly below the wash tub behind the lower toe panel directly below the door. To remove the panel, locate and remove the screws under the bottom front edge of the panel. With the screws removed, the panel will come off, exposing the drain pump and internal components. If you need further guidance, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Nov 17, 2010 | Washing Machines
How do I take off the back to get to elements and fuse on my kenmore elite dryer, I took screws off but the top appears to be welded.
Getting to the heating circuits is not the same on every model of dryer. Some dryers have heating circuits in the REAR of the dryer, some have the heating circuits located inside the cabinet UNDER the drum and others have heating circuits BEHIND the drum.
If your dryer has the lint screen on the TOP of the unit, you will need to remove the BACK panel of the dryer to expose the heating circuits.
If the dryer has the lint screen in the DOOR, you will need to remove the lower toe panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower toe panel comes off by removing the screws under the bottom edge of the panel.
If you do not have a toe panel, you will need to lift the dryer top and remove the entire FRONT panel to access the internal components.
If you have further questions, please post back with your MODEL NUMBER so I can determine how your dryer is constructed.
Mar 12, 2010 | Kenmore 62992 Electric Dryer
Cant remove the motor
If you have a front loading machine:
You can try to remove the front of the machine, this will expose the drum and belt, remove the drum and belt and this will expose the drum rollers, motor, and idler arm assembly. Then you can remove the motor.
I hope this helps
Oct 03, 2009 | Roper RES7648E Dryer
Leaking tub in front
If this is a Whirpool toploader and it is leaking from the front, this is commonly caused by a damaged drain pump. These pumps are sealed units and are not serviceable. So, if it IS leaking, the pump must be replaced. The following link explains how:
http://www.fixya.com/support/r397094-replacing_water_pump
Of course, the real determination will be exposing the internal components of the washer to get a better view. The link provided has all the steps required for removing the washer casing to expose the internal components. This will give you a better idea in determing where exactly the source of the leak may be coming from.
Run a small amount of water in the tub before you unplug the lid switch connector. The washer will not run with the lid switch disconnected, so you will need some water in the tub to see where your leak may be.
The drain pump is located in the front of the washer directly below the wash tub. Check the drain hose connections and the pump housing. As stated before, if the pump is leaking it must be replaced. Replacements can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Check the wash tub for any cracks as well, followed by a check under the center potion of the tub. If the leak is along the wash tub any where, the tub may have to replaced. If the leak is coming from UNDER the tub, you may have a leaky tub seal. These repairs are not difficult, but are labor intensive. We'll cross that bridge if needed.
Read through the link and let me know if you have any questions. I hope this helps you.
Aug 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag front load dryer thumps while turning, empty, full etc.
If your Maytag is like my Maytag, there are two screws at the two bottom corners of the front panel. Once you remove both screws the front panel will lift out, up, and off. Then you can see what is going on inside.
Mar 28, 2009 | Maytag Dryers
Calypso fl error
Look along the seam in the front of the washer where the top meets the front panel. About two inches in from each side is a retaining clip. If you take a putty knife and push in on the clip while lifting up on the top, the top of the washer should open up. You may need the assistance of another person and use two putty knives at the same time. It can be a bit tricky sometimes, but the top does open in this manner. Once you have the top open, carefully rest it against the wall behind the washer. There will be a screw holding the front panel on at each top corner. Once you remove the screws, the front panel should come off exposing all the internal components of the washer. You can also remove the back panel for additional access. I hope this helps you.
Sep 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Maxon HCB-10C CB Radio Logo
Top Maxon Radio Communications Experts
Steve
Van Allen II
Van Allen II
tvopft
Level 1 Expert
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
