Question about Powerware 9120 UPS System
Short backup time
Backup time reducing from 6 hrs of backup to a few minutes withing 4 weeks of purchasing new batteries. what is the standard charging Current (Amp) for the PowerWare 9120 1000VA ? mine reads as 0.44 Amp.
    Scholar:
  • 39 Answers
The only way you would get 6 hours backup initially from a Powerware 9120-1000 would be with no load connected(actually 378 minutes when I just looked at the one I have on the test bench). As soon as you apply a load, your displayed (and actual) backup time will reduced. Powerware have battery backup time versus load tables on the product info for the 9130 which is similar and a backup calculator on their website.
Posted on Feb 08, 2011
    Novelist:
  • 169 Answers
Suspect battery failure/faulty cell in a batt
Remove batts and check outside unit
charge up to around 2.27V/cell then check discharge on each batt (12V car lamp is good dummy load)
faulty one will be obvious.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Posted on Aug 02, 2010
How long does it take to charge battery for the first time?
Depends on the battery... a "toy" battery may only need an hour or two....a motorcycle battery may need 12 hrs @ 4 - 6 amps - depending on the type of battery....a car battery may need 10 amps for a short time (4 hrs) because they come pre-filled and charged. I NEVER depend on the "charge" of a new automotive battery (of any type)..I always charge them for at least 4 hrs @ 10 amps before initial use!! ...they seem to last longer
BUT - AS a RULE = 10 hrs @ 10% of the rated amperage...
Aug 16, 2017 | The Computers & Internet
I have charged my batteries for about 4 hrs and inserted into camera but after few minutes it indicates low battery signal
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 29, 2012 | Canon PowerShot A470 Digital Camera
I have toshiba M500 (6-celled battery)as the dealer person told that my laptop will give a minumum backup of 3 hrs but i can't get this much only 2 hrs is given why and is there any problem with my...
No there is no problem in your labtop or your labtop battery.
The life or the time of battery back up depends to what you work in your labtop.
So if you listen to music or watch videos the time of battery backup will be short because listening
to music or watching some videos uses much power to supply the devices of multimedia like the
labtop speakers and the hard drive motor ,in addition to the labtop FAN
All those devices needs more power to run .
But if you dont work in your labtop on any of these are membered and just surf the net or work
in other places the battery backup time will be longer.
Jun 13, 2011 | Computers & Internet
I have a brand new Kiddie CO alarm with lithium backup battery pack. I took the back off, plugged in the backup batter and plugged the unit in. I tested it and received 4 beeps, and another 4 beeps. Unit...
depending on the size of the battery, it can take upto 20 hrs to correctly recharge a lithium battery.
Leave the unit on charge overnight and if it still reads as low battery, return the unit to the place of purchase.
Jan 14, 2011 | Home Security
Can any one please tell about how to increase battery backup, its very less upto 1 1/2 hrs.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 30, 2010 | Acer Aspire Notebook
I have a Groovy Girls scooter by Kid Trax that was purchased about 3 years ago and it needs a 6 volt replacement battery. I cannot find one anywhere. Help!!
Do you know how to access the battery.. ? Probably under the seat etc.. Does it look like a brick with 2 spade connectors on top?
evx1273.gif 6 volt 7.5 Amp hrs.... These are the same batteries as used in most computer backup power supplies. http://www.apc-ups-battery.com/newsite/6P1270.htm
If it's more square shape then it's the type used in emergency lighting 6 volt 4 amp hrs
640.jpghttp://www.lightworld.com/viewdetails.asp?id=99910252&sub=843.
These and many more are available all over the internet and in specialized battery stores..
Shop around . The examples here are fair prices.
Dec 12, 2010 | Electric Kid Trax Groovy Girls Va Va Vroom...
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Dell Laptop Battery
watching dvd reduces the the battery power especially when its uesd simultanously with other computer application that may reduce the hrs but since your mobile you need a portable device,and the option is to purchase another battery with more Ampere Hour (AH)rating that will last for longer hours more than 4hrs
Jul 19, 2008 | Dell Latitude D820 Notebook
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
Powerware 9120 UPS System Logo
156 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
