Question about Epson RX595 Photo All-In-One Printer
I installed a new ink cartridge, and the printer does not recognize it. I have tried reseating the cartridge and have played with it over and over. What is the real problem?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 31 Answers
It could be inks or the printer. Try to reseat ink cartridges. Make sure you are using brand new Epson cartridges. Put it back in. Insure that it clicks into place. You may need to press a button or close the scanner portion in order to initialize the inks.
You can also try to use the printer driver on your computer. When using it, there are on-screen instructions for to follow.
If it is the same issue, try another ink. It could be that the inks that you have purchased are bad.
Same thing? Its an internal problem with the printer. You need to call Epson to discuss the warranty procedures. If they want to further troubleshooting.
Posted on Jul 06, 2010
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Epson stylus sx115
Hi, there is a possibility that the ink cartridges that you installed are not recognized properly. As a solution for that, try reseating the affected cartridges. You may also ask your vendor if they can replace the cartridges. Upon trying a different cartridges and issue persists, please contact Epson to process the warranty for your printer or ask a nearest service center in your area.
Nov 16, 2011 | Epson Office Equipment & Supplies
Anyone knows how to solve error 15 on canon printer mp150?
E15 Ink cartridge is not installed. Turn off the printer. Take out the ink cartridge and then reseat it. Turn the printer back on and see if it recognizes the cartridge. If it doesn't then try another new ink cartridge. Make sure its one from Canon and not a 3rd party refurbished one. If it still gives you the error message then that means the main board in the printer is bad and you would need to replace the printer.
May 22, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
How can i reset my epson printer installed new ink and it does not work
hi there, if the ink is not being recognized, try to reseat the cartridges, here is the link on how you can do it, look for remove and install cartridges, the cartridges might not just installed properly
http://files.support.epson.com/pdf/r300__/r300__u1.pdf
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Nov 27, 2009 | Epson Stylus Photo R300 InkJet Printer
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
I have an Epson CX8400 printer and I just installed new ink cartridges (genuine Epson)all four and I get the error message "cannot recognize ink cartridges".
Try the following:
1. double check the part numbers of the cartridges and also their expiration date.
2. reseat the cartridges
3. after you place the cartridges back, close the scanner part and press and release the stop button.
4. If same issue, either an issue with the cartridge(s) involved or the printer itself
Hope this help
Feb 25, 2009 | Epson CX8400 All-In-One InkJet Printer
My magenta ink cartridge isn't being recognized.
Check for trash in the way and reseat. Try reseating the magents firs, listen for the click that tells you that contact has been made
Dec 31, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
New Magenta Ink is not recognized after installed
Hi, it sounds that the issue can be caused by a defective ink cartridge that installed or a printhead that can recognize magenta ink cartridge. To identify which causes this issue please try the following:
1. Reseat ink cartridge
2. Replace ink cartridge with a specified ink cartridge for your printer.
3. If above steps wont resolved that issue, please call your printer manufacture and ask for service referral or process warranty options.
Tirzo
Oct 21, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Epson RX595 Photo All-In-One Printer Logo
429 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
