Question about Vacuums
When I turn on my magic mic and set the tv to video 3 it is scratchy but the sound is there. How to solve this problem?
  • asc1970 Jul 06, 2010
    I have an old magic microphone color black, model ET. I have problem viewing the screen when I turn on the tv. The power on is okay and the sound is clear. My problem is I can't view the screen because it is sratchy. I don't have this problem when I plug in to my cousin's house tv. Please help!
  • 677 Answers
Hi you can troubleshoot the cable your using for connections and after troubleshooting cables,you can also check the TV input plug in port if it is working well,
I think that will do.
Take care.
Posted on Jul 07, 2010
  • Vacuums Master
  • 3,083 Answers
Either the mic has a bad solder or wire connection inside it, or it has a power supply, amplifier, or transmission problem. The unit is going to have to be taken apart, and troubleshot. Make sure it works the same way on another set, just to make sure the set's not off-frequency, etc. Once you know the mic's the problem, you will have to open it up and see what you can see. This could be a capacitor in the power supply circuit going bad, but not likely- most likely will be a cracked solder trace or wire. Inspect it with a magnifier- cracked solder joints are hard to spot with the naked eye, often times. Also, a switch could be going bad- they're always to be suspected. Haven't heard of this problem, so that's all I can offer about it. Good luck, and hope this helps.
Posted on Jul 06, 2010
    This particular magic mic works fine with my cousin's tv. I have another one that I am using with the same year and model with no problem whatsoever when plug in to the same tv that i have.
The dirt sensor light stays green. It won't turn red, even when I know I'm picking up a lot of dirt.
The Board(46851083) is No Longer Available
The EDF Duct (47823004) EDF= Electric Dirt Finder is $20.40 from
http www searspartsdirect com model part u6485900 0517 0645000 50039309...
You can test the board by crossing the 2 connectors to "close" the circuit for the mic (small black and blue wire) while vac is running and light should go to red every time you complete the circuit. WARNING: There will be exposed electrical points on board that could cause an electrical shock!!! or damage to board if not just crossing mic connections.
Jan 22, 2016 | Hoover U6485900 Bagged Upright Vacuum
I cannot hear the videos on you tube anymore
If you don't hear sound on YouTube videos, please try the following steps:.
  1. Adjust the volume control on your computer and speakers.
  2. Adjust the volume control located in the lower left corner of the YouTube Video Player.
  3. Restart your internet browser (Internet Explorer, Firefox, Chrome, etc.)
  4. Ensure that the volume is turned up on other video players, such as Quicktime, Real Player, or Windows Media player, as this might affect the video player sound.
If you still have no sound after trying the steps above, you may want to try the steps below:
  1. Install the latest version of Adobe Flash (necessary for streaming YouTube videos) after removing any old versions you've installed. Learn how to install the most recent version of Adobe Flash player.
  2. Allow third-party Flash content on your computer by visiting the Adobe Flash Global Storage Settings Panel and following the instructions. Once this is complete, close all browser windows and try re-playing the Live Event.
    Please be advised that this action stores a Flash cookie on your computer. Flash enables this by default upon install.
  3. Check your Antivirus and Firewall software to see if you're blocking third-party Flash content
Dec 04, 2012 | Vacuums
Vacuum turned off started smelling and got hot but only for 2 to 3 minutes then turned off
Hi There, 2 to 3 minutes is too short for a blockage in my opinion. I would suggest you have a burnt out motor. Did it make any kind of uneven sound or popping sound? If yes then you will need to replace the motor. There are a couple of good videos on youtube to help you out if you are suitably qualified or skilled. This is a pretty tricky repair though I would give it a 7/10 for difficulty.
May 31, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My brand new dyson dc33 vacuum ($399.00) is making an annoying sound when applied using a carpet setting. This only occurs on my thinner carpets, not on my thicker carpets. Do I have to inspect the...
If there are no obstructions and it still makes the grinding noise here is something to try. When you take the bottom plate off which is real easy to do (3 plastic screws turn 1/4 turn with a coin) there is also on the bottom of the vacuum a rubber seal. This is located just above where the screws are inserted. Take a butter knife and remove this seal...it is very thin and runs the width of the bottom of your vacuum. Put plate back on and try vacuuming again..problem should be solved. The suction on the machine is tremendous...with the seal in place the vacuum literally sucks itself down on the carpet causing the brush to stop spinning. This wwill not hurt your vacuum in any way. Hope this helped.
Reply
Jan 05, 2011 | Vacuums
Eureka canister vacuum cleaner Model 6865
The 6865 has a high rpm AMTEK Lamb motor, Brushes will seldom solve the problem at this stage.
Once the sparking and burning starts the conectiion between the brush and commutator is arcing and burning. If the sparks are blue, save your time.
A good service tech will run in brushes with a seating stone and a low voltage setup to allow new brushes to seat, but this is generally best accomplished on heavy duty , lower rpm motors.
IF YOUR ARMATURE IS SCRATCHY LOOKING OR WORN LIKE AN APPLE CORE,OR THE SEGMENTS ARE NOT PARALLEL IN THE SPACING YOU WILL NEED A NEW MOTOR.
Oct 16, 2009 | Vacuums
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Carpet Magic Steam Machine Hr 3-2 Leaks
carpet magic steam cleaner pump problems.
Apr 24, 2009 | Vacuums
Roller brush of vacuum not rotating
u might need 2 change the belt on the attachement there r 2 screws on top take em out after u take off cover there is a plastic cover over the belt take off c if the belt broke the rest is easy
Apr 15, 2007 | Kenmore Magic Blue 24195 Bagged Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
