Question about Mmats Procast 15 Car Subwoofer
I have a pair of 15" procast mmats and need to replace the rubber seal around the cone. Where can i get a repair kit ?
  • 4 Answers
Well i havent had just the rubber problem, I've complete recoils. Contact MMATS. They should do it. http://www.mmatsproaudio.com/ Click contact then email
Posted on Aug 05, 2010
How can replace the speaker the bass sound is broken
Dear Rob,
Really Thankful for the detailed description for the Speaker Repair.
It really helped me a lot. I have a unusual situation here with me. I have dissected the whole console and found the outer band of the speaker has just come off....have attached photos to make it clear. does the outer speaker cone will make a difference or i will have to replace the speakers itself.....when i checked pressing the speaker down and played the distortion had gone....but while playing without holding the distortion would come back....Hope you can help me in this situation....Thanks in Advance..... 714812a0-935e-4f95-922e-50c6ba281b9c.jpg 36e62701-6370-491a-a317-a11c69cc9525.jpg
Jan 13, 2013 | Harman Kardon Go + Play Portable Speaker...
I can't remove the speaker
Remove the protecting grill in front. Check if the cone is still connected to the rubber band. If not, remove the screws around the speaker. Open the casing itself. Do not forget the screw in the middle of the battery compartment. Remove the bottom cover. Disconnect the 2 wires on the speaker and take out the speaker. It will come out with the plastic protection around it. Looking at the cone now, push up the Carton cone and keep it in place by putting some tissue paper or small cloth underneath. Clean the cone first. Use some rubber cement on the outer edges of the cone and press the rubber back on the cone. Let it dry for an hour and then remove the tissue / cloth, so the cone goes back to its normal position.You can use some extra rubber (those pre-glued strips that you would use to fix a bicycle tire) to make it extra strong. Remount everything back in place and voila....it works again!If your cone is not damaged, the casing most probably does not seal good anymore. Tighten all screws a little more and use plastic electrical tape all around to seal all joints. The bass is produced inside the casing itself and pushed out via a horn. If it is not closed off well, your bass sounds grumpy.
Oct 08, 2012 | Harman Kardon Go + Play Portable Speaker...
It is rip in to little piecies
It may not be worth the expense, but if the cone or surround are torn, they can be replaced by a speaker repair shop. I just had a pair of JL 10W6's re-edged (the foam surround around the cone deteriorated after 11 years), and the repair cost $100 for the pair, including parts.
Nov 01, 2010 | Thump TBB102 Car Subwoofer
Does mmats sell the rubber surround for a 12 inch procast? one of my procast needs a new rubber. Do i have to sent it in or can i fix it at home/
You can do it yourself if your handy. Lots of places out there selling them. Not too bad a job. Takes some patience gettiog the old one off.. If its really rubber and not foam, it'll come off in one peice. Have to be carefull the get the cone centered when ya glue the new one in. If you decide to tackle it get one with instructions and/or a good web search on the surround replacement.
Apr 06, 2010 | Mmats Juggernaut 15'' Car Subwoofer
Seals around speakers are broekn and gone!
Hello kagato_morri,
While it's certainly possible to replace the surrounds, whether it's economical to do so is another question. For very high-end speakers, there are often "repair kits" available to replace spiders, cones, surrounds and for some, even the voice coils. But such parts are usually not available for your run-of-the-mill speakers.
If the speakers are otherwise in good condition, and you are willing to spend some time with them, you can use an adhesive foam to construct a new surround. A product called "shoe goo" makes a good permanent bond. It's a super strong rubber cement and will hold up under the stresses of the moving speaker cone.
Hope this helps.
May 23, 2009 | JVC Car Audio & Video
Speaker repair
Contact MMats Pro Audio at 561-842-0600. They can re-cone it for you, or sell you the re-cone kit. If that does not work for you, contact MWA Speaker Parts in Tuscon - 520-647-7193. They can sell you a re-cone kit, or they can direct you to a speaker repair center near you. A third option would be to contact Sundown Audio in Troutman, NC. They may be able to re-cone it for you.
Apr 18, 2009 | Mmats Juggernaut 15'' Car Subwoofer
Kicker L7 plastic faceplates
You will have to buy the whole cone replacment kit for that part or get from bad speaker. Both can be purchased on ebay or other sites.
Feb 02, 2009 | Q-Logic QLT-.3508SS Car Subwoofer
Mmatsd500.2
First, the specs:
  • PPI 4200am = 50x4 at 4 ohms, 100x4 at 2 ohms
  • Alpine 3553 = 35x4 at 4 ohms, 50x4 at 2 ohms
  • Mmats D500.2 = 350x1 at 4 ohms, 500x1 at 2 ohms
  • 3x Mmats Procast 12 = Dual 4 ohm VC
  • 1x JL 15w6 = Dual 6 ohm VC
  • 2x JL 15w0 = Single 8 ohm VC
Second, I don't think I would recommend mixing n' matching the subs. One of the subs would always be working harder than the rest. If you want to run multiple subs, make them all the same. Sometimes, you can get away with it if they are all the same voice coil impedance, but in this case you've got dual 4 ohm, dual 6 ohm, and single 8 ohm subs all in the mix.
If it were me, I'd probably stay with the single 15w6. But it's your money :)
Mar 12, 2008 | Mmats D500.2 Amplifier Car Audio Amplifier
Mmats Procast 15 Car Subwoofer Logo
112 people viewed this question
Top Mmats Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tariq Waheed
Tariq Waheed
Level 1 Expert
Are you a Mmats Car Audio and Video Expert? Answer questions, earn points and help others
