I need the part number for a lanier ld 032c. I need the motors that spin the feed tires for trays one and two. The machine displays a jam and the paper doesnt move from the trays. Thanks
  • yan dikshteyn Jul 06, 2010
    no this doesnt help its not a part manual
  • yan dikshteyn Jul 07, 2010
    the copier model number is ld o32c none of these parts fit this copier from precision roller
  • 2,272 Answers
Your copiers model number is  LANIER LP226CN it is the unit  and theld 032 is the number of magenta cartridge in the copier unit. GENUINE LANIER LP226CN MOTOR  - GENUINE RICOH PART.  The motor part number is:---  Mfr Part #: GX060021, GX06-0021
PR Order #: B2760 .  --------------- PAPER FEED - Bypass Paper Feed Roller - Genuine Ricoh PartOEM PART #: GF031003
PR ORDER #: H3197 ------------- PAPER FEED - Manual Feed Separation Pad Assembly - Genuine Ricoh PartOEM PART #: G1022713G102-2713
PR ORDER #: E5825
---------- PAPER FEED - Paper Feed Roller - Genuine Ricoh PartOEM PART #: G0523103G052-3103
PR ORDER #: H3316
--------- For all the parts for your copier please click on this link http://www.precisionroller.com/find/lanier_lp226cn.htm --------- You can also directly contact this site if to get any inquiry before ordering any part.To confirm the part. Contact us by phone:
Toll Free: (800) 323-9523
International & Local: (623) 581-3330
Fax: (623) 581-6453
Order Fax: (800) 832-4548
Hours of Operation:
Website: 24 hours, 7 days a week
Online Chat: Mon - Fri 7am - 4:30pm MST (no DST)
Phone: Mon - Fri 7am - 5pm MST (no DST)
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 06, 2010
  • 472 Answers
If manual can be any of your help. Click on the link below to get to the website. select the model number and download it
http://www.lanier.com/downloads/Default.aspx?hbn=manuals
Good Luck!
How can I get A Lanier LD-620C parts manual
The LD-620 appears to be a Ricoh Aficio MP-C2051 or C2551.
You should be able to find a parts list on the net. Whichever one looks the same as your lanier (who don't make anything) will be the one.
Good luck
Oct 03, 2014 | Lanier Office Equipment & Supplies
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
The printer is showing a "p" on the display. what does this mean?
The "P" means that you need to add paper into the paper tray or in the manual feed tray. Odds are that you are getting a paper jam from the paper tray? I would try to fill the paper tray with paper & make sure the copier is on a level surface. You may need the paper feed tire's or you may have a paper present sensor broken? I would just use the manual feed tray. Good Luck
Oct 17, 2010 | Sharp AL 1631 Copier
I have a Lanier LD 232c. Every print job we try to send through is resulting in a paper jam. What should I look at?
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
Jul 06, 2009 | Lanier Office Equipment & Supplies
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
Cannon copier
Where is the machine saying the jam is located? Does the paper even start to feed? Does the paper feed to the next feed area? If the machine sounds like it is feeding ( trying to feed) and the paper is still in the tray --- clean the feed roller/ tire with rubber restorer or a high alcohol base cleaner. IF the paper is fed part way out of the tray to the long ( most of the time) black reg. roller and now farther --- clean the reg. roller. There is always the chance that you have a bad feed motor or reg. motor. Also look to see if an actuator / switch has been pulled / knocked out of position. They is is small cradles and can be snapped back into place.
REG = registration
Jan 06, 2009 | Office Equipment & Supplies
Lanier LD 325 Printing labels
4 x 6 might be too short for that copier to run on. The bypass tray might take it if you load it so that the 6" side is the longest end that the copier is feeding throught the machine.
If you have it interfaced as a printer, goto avery.com and download their label making software and find the template that matches your label stock. The software works with Microsoft Office files as well.
Jul 18, 2008 | Office Equipment & Supplies
Canon ir2016 pc
I have some GENERIC suggestions, but as I work on competitor products, I am not familar with the specfics of your machine. So this may or may not help. If something in this post doesn't match up with what you see, disregard it.
Generally speaking paper jam messages are generated because the sensors in the machine either see paper when the should not, or DON'T see paper when they should. "Ghost" jams are usually caused by two things: either the paper is not feeding properly from the paper tray or a sensor is "confused" because it is bad, broken, or covered by a small piece of paper.
If the machine indicates a jam in an area of the paper path close to the paper tray, it is likely that paper is not feeding from the tray at all. If you have an alternate paper source, such as a second tray or a bypass, try feeding from that source. If you are successful, the problem is probably misfeeds from the tray that doesn't work.
In that case, inspect the feed components in the tray (feed rolls or feed tires as the case may be). See if anything looks out of place. Sometimes feed tires can twist or slip and can be put back into the proper position. If the machine has two similar trays, you might be able to compare the two. If you can, remove the tray and see if you can locate the actuator for the paper empty switch. (It will probably be a plastic lever hanging free to ride on the top of the paper stack.) VERY CAREFULLY (you don't want to break or dislodge anything) tape the lever up in place (to fool the machine into thinking there is paper in the tray) and then inspect the feed components while you attempt to make a copy. (Be sure the tray you are watching is selected as your paper source.) If the feed components turn, you probably have to replace the rolls or tires. If not, it may be that a feed clutch or solenoid is not working.
If you cannot get a successful feed from any source, you may have a sensor problem. This might be a bad sensor, a broken actuator or a very small piece of paper stuck on a sensor. This latter problem happens when someone pulls out a jam. The paper tears on the sensor actuator and leaves a small piece in the sensor. Look around the area where the jam is indicated and see if you can find the sensor actuator. It will be a small plastic "finger" or lever (it may only be a few millimeters) typically with a small spring on it. BE CAREFUL not to dislodge or break it. See if there might be a small piece of paper (it, too, may be just a few millimeters) on it or anywherer else in the paper path. If you see something, carefully remove it with tweezers or a similar tool. Again, be very careful not to break or dislodge the actuator. If an actuator is dislodged, you may be able to pop it back in place, but if the small spring has fallen off, it might get tricky. The end result is that the actuator should move freely and spring back into place.
The truth is, unless you see something obviously out of place, or you are exceptionally mechanically inclined, it is probably best to get a service tech in. Again, these are generic tips, but I hope they give you some help. Good luck!
Mar 27, 2008 | Canon PC-940 Black and White Copier
Paper Jam
We need to the model/make to help you
but using some detective skills I've decided you are using a HP machine
Yup Dirty damaged worn feed roller but what model machine is it they are all different but pull out tray 2 cassette all the way and look in, there is probally a cylinder like rubber roller 5cm wide front centre of where cassette slides in, there might be roller on the cassette too at the front center as well.
Most modern printers feed rollers just slide off after lifting small plastic tabs on them and gently pulling, feed rollers are available but you can sometimes also get results by cleaning them with a dash of metho or water on a rag.
If paper feeds 2wo sheets at once then you need to change the seperation pad/roller too.
Nov 01, 2007 | Dell W5300N Laser Printer
52 people viewed this question
jasbo
jasbo
