Question about Frigidaire FAP094P1Z Portable Air Conditioner
I have a Frdigidare portable AC/Dehumidifier and have had it sored in my very clean garage all winter. I set it up today and it seems only to be running as a fan. I do not hera it "turn over" like an AC and it is NOT cooling the room. I have the white expandable tube vented out a window and that is very hot to the touch but it is very hot out. Model #FAP094P122 - pLEASE HELP!
5 Suggested Answers
RepairUSA
  • 50 Answers
SOURCE: Window AC takes spells on cooling?
One thing to check is to make sure the evaporator and condenser coils are clean. Any dirt here will short ccle the compressor.
Posted on Aug 25, 2007
  • 659 Answers
SOURCE: hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Posted on Mar 31, 2009
  • 14 Answers
SOURCE: window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
Posted on May 03, 2009
  • 2976 Answers
SOURCE: my frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
Posted on May 25, 2009
Override temperture setting on Amcor Amc-12000e portable Air Conditioner
Actually there is no way to do what you want because the unit is designed to operate when the inside temperature allows the heat exchanger to function so that it will condense the liquid refrigerant into a gas.
As far as using it in the winter to dehumidify this same applies. If it is to cold then the gas won't be able to condense back into a liquid. If I were you I would buy a portable dehumidifier but remember that if the temperature is to low it won't work.
Good luck
Marty
Mar 01, 2014 | Amcor PCMB-12000E Portable Air Conditioner
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
Danby Portable A/C Model DPAC 11007, purchased Costco May 19, 2007. Platinum Warranty. For the first few years A/C( only) operating it was not necessary (or rarely) to empty the external tank Then last ...
Eugene, first, let me say, yours is one of the best narratives, of what is happening with your ,that I have read in a long time. You didn't leave me guessing as to what was going on.
I believe one of the problems is that you may be operating the AC Cooling & the Dehumidifier at the same time. If this is the case, the dehumidifier is generating heat, when it's operating and the AC cooling side is working at a lower rate, because the dehumidifier is in operation. Discontinue the use of the dehumidifier on extremely hot days and use only the AC Cooling mode. The AC mode also acts somewhat as a dehumidifier. That's why draining the water tank is required for AC mode too.
I would also be prudent to check the exhaust hoses to make sure they are not clogged or have been bent out of shape. Keeping the air intake filter clean is really important, too.
Aside from the air conditioner, other things can be done to help cool the room. Close all drapes or blinds to block the sun from directly heating the room. This is especially true, if the AC unit is sitting in direct sunlight. If you have a ceiling fan, operate it it as fast as you can stand, in a Clockwise direction. This not only keeps air moving, it also helps the AC unit and creates a windchill, that fools your body into thinking it's cooler than it really is. Personally, I have been doing this for years and have saved a ton of money on electric bills during the summer.
I hope I have been able to help you and thanks for choosing FixYa.
Jul 25, 2011 | Heating & Cooling
I have a Kenmore 54501 Dehumidifier. Just plugged it in today and it runs but no water is in tank. What could the problem be? It worked great last summer and was not plugged in all winter.
You may have the humidity extraction level set higher than the humidity level in the house. Lower the level to 32 to 35%. Also, remove and check the air intake filter for dirt or clogs. Clean if necessary.
Hope this helps you solve the problem.
Jun 09, 2011 | Kenmore 54501 Dehumidifier
The dehumidifier is running but very little water is going into the tank. I cleaned the filter, long overdue, and it didn't help. Everything seems to be running well. I also have the room humidity level...
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
May 07, 2009 | Fedders A7DH45B2A Dehumidifier
2008 Frigidaire 50 pint Dehumidifier from Lowes
You can test it out by disconnecting the power cord, wait five minutes and plug it back in. If it retains the original settings you are good to go. If you are wondering before purchasing a new unit ask before you buy.
Apr 25, 2008 | Frigidaire FDL45P1 Dehumidifier
Frigidaire FAP094P1Z Portable Air Conditioner Logo
43 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
