Question about Frigidaire FGBD2432KF Builtin Dishwasher
Fghd2433kw error code uo what is this - Frigidaire FGBD2432KF Builtin Dishwasher
What does the Frididaire dishwasher error code uo mean?
Good Morning Friend, this is Z. Thank you for your question!
Error code UO commonly means that the vent is in an open position. While your Frigidaire dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly.
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your dishwasher. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jul 07, 2014 | Frigidaire Dishwashers
Frigidaire 24 in. FDB4315LFC3 STAINLESS STEEL ERROR CODE UO
Hi Mark, thank you for your post!
Before reaching out to a professional, let's try resetting your dishwasher. This can be done by flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn your dishwasher on. This often clears most false-error codes. If resetting the power does not correct the issue, a professional will need to check the wiring between the vent assembly and main control board.
Best of luck!
Jan 18, 2014 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire dishwasher error code
Hello Teresa Ann - Typically error code UO indicates that while the dishwasher is in wash cycle, the main control board is not receiving signal from the vent assembly and that the vent plunger is in a closed position. A professional will need to check the wiring between both parts and depending from the results either part may need replacing.
Jan 19, 2013 | Frigidaire Dishwashers
Frigidaire dish washer FDB4315LFo Error code uo
You are experiencing a vent issue - While in wash cycle, Main Control Board does not receive signal from vent assembly that vent plunger is closed. Plunger status is sensed with optical sensor in vent assembly. Check wiring between vent assembly and Main Control Board. If wiring correct, replace vent assembly. If error still exist, replace Main Control Board.
Sep 04, 2012 | Frigidaire Dishwashers
I got a code from auto zone that is i believe UO 101 AND UO105 OR UA101 AND UA105 WHAT do these codes stand for
These codes are communications code errors:
The UO101 is a transmission communication error: poor communication to your transmission ECM / computer
The UO105 is a fuel injection communication error: Poor communication to your fuel injector ECM/ computer.
Jun 15, 2011 | 2006 Dodge Stratus
FP 7750 copier error code U0
"Uo" means the machine requires the key counter to be installed OR for a 3 digit access code to be entered.
Jun 06, 2010 | Panasonic FP-7750 Black and White Copier
I just installed a new Frigidaire dishwasher. Took it through 1 cycle as the directions indicate looking for leaks. I now have it full of dishes for its maiden voyage, and I get an Er uo code. Cannot find...
this is a vent problem you need to check the vent motor and make sure tha the wire have not been pinched by the door spring and make sure it is connected properly.the vent should be located on the top or possibly the right side of the cabinet.
Feb 07, 2010 | Dishwashers
Error code
We had the same problem with our Frigidaire dishwasher (different model though). We called them and they said the UO stands for Vent Open (the display can't make a V so it makes a U). The active vent was not closing when it should be closed (the repairman said the gasket was stuck up in the assembly so sometimes it would seal and sometimes it wouldn't) and thus the error. Since our machine was still under warranty, we had the vent replaced at no cost and haven't had the problem since.
Nov 26, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Error code ER then UO any ideas?
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire FGBD2432KF Builtin Dishwasher Logo
107 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
