Question about D-Link DIR-615 Wireless Router
Dir 825 router it will not connect to the internet
  • 2,260 Answers
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Posted on Jul 07, 2010
XopenX
  • 108 Answers
SOURCE: Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Posted on Jan 15, 2009
  • 3 Answers
SOURCE: DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
Posted on May 29, 2009
  • 25 Answers
SOURCE: D-Link DIR-615 Internet LED light not working
Even though we need more info to resolve the issue, I will make a guess here. My guess is that your D-Link is not configured right, (ie. not pulling the proper info from your ISP's DHCP server.
Try restarting the router and restart or repair your network connection on your pc. Secondly, try to do a "hard reset" on the router, or restore to default. Then reset your connection on the PC. Third, manually set the info on the router.
If you are wireless, you have a whole different issue.
Posted on Aug 14, 2009
  • 9 Answers
SOURCE: My D-link dir-825 router has been giving me poor signal
Hi Friend,
Firstly,u need to do following settings to u'rs belkin router: Default ip address of D-link dir-825 is 192.168.0.1
,so you can login to router setup page by http://192.168.0.1
1> You need to reduce MTU<Max.Transmission Unit> to 1400
2> Change wireless channel to 9/11
3> Wireless MAC ADDRESS CONTROL should be disabled for u're xbox
4> Reduce beacon interval to 50/75
5> Fragmentation Threshold:2306, RTS Threshold:2307
6> Disable the security/firewall of u're router
7> Do the port forwarding/trigerring;port numbers for xbox are:53,80,88,543,3478-3479,3658,5223,10070-10080
it will be good if u change wireless network name(SSID) as well as upgrade the firmware of u'rs router;so that it will reflect the effect & power down u're x-box while doing the changes in router.
If u need technical help in order to do the above changes in router have a words with belkin technical suppoprt.
Posted on Mar 19, 2010
SOURCE: Wireless connection DLink Dir-825 to printer lost.
How to recover wep key information
Posted on Jan 13, 2011
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
My ISP gave me a USB modem(Wanadoo ADSL) which i connect my telephone line and a USB to connect the modem to my pc.I bought a D-link DIR-825.Do i connect the telephone line directly to the DIR-825 or i...
Plug the modem filter in the wall, plug the modem into the filter, then plug the router into the modem. From there you should be able to set up your network or personal internet.
Mar 12, 2011 | D-Link DIR-825 Wireless QuadBand Router
Cant connect wireless to internet with dir-825
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 31, 2011 | D-Link DIR-825 Wireless QuadBand Router
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
Desktop works fine connected to cable modem but when hooked to dlink the internet connectivity
If you connect the desktop to the modem it works that means modem is working.
Now connect the modem to the router and computer to the router.
Open the set up page of the router. and change the settings of the router according to your internet service provider.
Click Here for step by step instructions
Dec 05, 2009 | D-Link DIR-825 Wireless QuadBand Router
D-Link DIR-615 Wireless Router Logo
746 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
