My dryer is not heating up; results it does not dry.
Well first of all you can check out power from the house - check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. After then you can check the heating element - Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it, note: electric heating elements are not repairable. Further you can check the thermal fuse -
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long, is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Good Luck!!
Thanks for using FixYa!!
