Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer stop with a code of HP - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 3,053 Answers
Hello, jw I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Invalid heating temperature
A dryer starts, runs 30sec and stops w/ code (hE) what panel do I remove to access the thermostats for ohm testing
Sep 09, 2012 | Samsung DV218AEW Electric Dryer
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Fridgidaire dryer stops with code PF
pf isd power failure
with so many differant possiblities
it would be hard to nail it down here
but i would check my outlet chord and termianl post
where the chord connects to the dryer
one or more of the connections could be loose
Jul 01, 2009 | Frigidaire Electric Dryer
Dryer stops & gets F04 code. ?? what is this code, can't find it in my book. Thanks LW
the F04 code refers to improper venting of the dryer.
either your vent is too long, or blocked by lint or a crimp.
dryer vents should be no longer than 10' in flexible venting or 15' in rigid venting.
alot you will find that at the EXIT port outside your house is clogged with lint. remove the lint and you should be ok.
May 26, 2009 | Kenmore 84072 Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 25, 2009 | Kenmore 67082 Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
My Mag neptune dryer shows HP and stops drying
Hi again mssunnybunny,
I just thought of something,
You did not give a lot of details so pose this question just in case!
You only said, Your Mag Neptune dryer shows HP and stops drying!!!!!!!!!!!
1.Does it go but not get hot and not drying??
2.Or does your dryer not go and then make a loud humming sound like it's trying to go??.
If # 2 is the description and this was the case, then you need
a new motor!
Sep 13, 2008 | Maytag Dryers
Stopped working
It might be overheating.  Make sure your dryer vent is clear.
Oct 16, 2007 | Kenmore 84052 Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
