Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Model PTC093B35AMBP .AC unit will not start., fan will not start.
  • Amana Master
  • 8,220 Answers
The very first thing to check is the capacitor. If it looks swollen or leaky it probably has failed. Model PTC093B35AMBP .AC unit will not start., fan - 25795c3.jpg
When both fan and compressor won't work their is an excellent chance this is the problem. If that is ok the control would be next suspect. Since BOTH compressor and fan won't run you either have a capacitor or control switch malfunction. I am leaning towards the capacitor route. Let me know
Posted on Jul 06, 2010
My amana ptc093b35ambp unit in a hotelroom will start but only blow warm air what should i check?
there is a run capacitor in the unit that needs to be check by using and ohm meter the rating is written on the front of the capacitor in mf called microsfarads. have you cleaned both of the coils the inside and outside. I would first take it outside and wash the units coils with a water hose you will need a spray attachment for the hose to get the pressure.
Sep 16, 2014 | Heating & Cooling
Chrysler lhs overheating. fans dont run, fuse is good
odds are your fan relay is out. I take your model has two fans with seperate eletric motors.
Nov 03, 2011 | 1997 Chrysler LHS
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Carrier AC Model No. 38CKS fan not spinning
You have bad cccccccccapacitor in your outside unit. Not hard to replace but you need to find someone to sell you one It should say 45 5 or 50 5 on the side of the capacitor. You can also call a service tech about 150 for the repair. Rus Carrier Dealer 45 years
Jul 18, 2009 | Heating & Cooling
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
1990 model RUUD AC unit. Fan runs, no cooling
Is the outside unit running? Fan and compressor?
Jun 29, 2009 | Heating & Cooling
For some reason my AC started making a clanging noise. Upon checking I found that the blades went flying off the fan. How can I fix this
need a new fan blade. might want to check out your local wholesale parts store. make sure you take unit model # and s#
May 23, 2009 | Haier (HPE09XC6) Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
400 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
