Question about Garmin Nuvi 660 GPS Receiver
My garmin nuvi says no map data availible and i cant enter address search
  • Garmin Master
  • 6,993 Answers
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
  1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
  2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
  3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
  4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
  1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
  2. Hold the switch in the position for at least eight seconds.
  3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
  1. Turn your Nuvi off by sliding the power switch to the left.
  2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
  3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Posted on Jul 06, 2010
All of a sudden my garmin 3790LMT shows "no map data available" how to fix?
Is the SD card containing the map (and update) inside the Garmin device yet ?
Sep 16, 2016 | Garmin Nuvi 3790 LMT GPS
Garmin nuvi 255w missing postcode search
On my Nuvi 200, after "Where To?", you have to select "Address". My instruction book says: 2.Change the state, country or province if necessary. 3.Touch "Spell City", enter the city/postal code, and touch "Done". Select the city/postal code in the list. (Not all map data provides postal code searching). If you are unsure of the city, touch "Search All". There are further steps, but "Depending on the version of maps loaded on your nuvi, the button names can change and some steps could be ordered differently".
Oct 09, 2014 | Garmin nuvi GPS
Gps nuvi it alays say no match found
Every Garmin Nuvi has a map info screen. check to make sure your Garmin has maps
usually that screen is
Tools;
Settings;
map;
mapinfo (at the bottom)
or
Settings;
Map and Vehicle;
My Maps;
If it is greyed out or a blank screen then your garmin is missing its maps. otherwise, make sure the maps are checked and make sure you are searching in the right area. by default the Garmin will search within 50 miles of you.
Aug 03, 2014 | Garmin nuvi GPS
"No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Dec 12, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 660 lost map data
take it back to the store you got if from and get a tom tom
Aug 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 360 keypad stuck
operator error - search doens't work with Topo maps, only city navigator. changed map and worked.
Aug 20, 2008 | Garmin nuvi 350 GPS Receiver
No data available mess
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench, then press Map, then look for Map info.
Jul 12, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi says "No Data Found"
I had the exact problem and i called 800-800-1020 to recieve two unlocking files from the Garmin assistant.
May 25, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
32 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
