Question about Maytag Neptune MAH5500B Front Load Washer
Replace tub bearing on Maytag front load washer
Krazytech
  • 725 Answers
SOURCE: WAsh machine drum bearing removal
check out the tommy tool on youtube .it will show you how to do it even if you don't buy the tool...
http://www.youtube.com/watch?v=F3Wrq6Yxra8
let me know krazytech
Posted on Aug 13, 2008
aborcass
  • 2651 Answers
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Posted on Dec 03, 2008
  • 130 Answers
SOURCE: Maytag washer MAV551EEWW top load with loose tub
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
Posted on May 07, 2009
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
  • 176 Answers
SOURCE: Loud noise from Kenmore front loading washer
Here is a compilation of my advice on repairing these units
This is a cronic problem of front loader machines. The two bearings that hold the wash drum are dried out and then they over heat. The heat builds up and weakens the seal that keeps water in and grease out starts to leak and the problem just becomes worse with every load. A service repair man will charge you the cost of a new machine to fix the unit. You can replace the bearings and seal with parts from a bearing supply store and if you do, only use bearings from Japan or Germany. Your machine came with ones from China and that is why these machines are failing after so many years.
The bearings on the back of the outer shell, the ones that spin the drum, are finished. There is also a seal on the inside of the shell that keeps water from leaking and it is leaking also. As a result the brown grease from the bearings is seeping past the seal and contaminating your wash. You need to replace the bearings and seal to fix the problem. You can go to your local appliance store and order the rear half of the outer shell for about $230.00 and have the same problem in 4 years. Or you can buy the bearings and seal at a bearing supply store for about $100.00.
The part numbers needed are:
Seal #408010 DAE (vulcanised double lip seal)
Rear bearing 6308 (sealed bearing)
Front bearing 6307 (sealed bearing)
The bearings to buy are made in Japan. If you buy cheep China bearings then you are asking for trouble because that is what was in your machine to start with. Timkin and *** are 2 of the best made bearings.
To remove the bearings you can use a hammer and a metal punch. To install them use a hammer and a 2X4 on end and be careful not to damage the bearing. This is easy to do.
An appliance repair shop will charge you the price of a new washer to do this repair. The choice is yours.
The hardest part is the door bellows. Not too hard, just need a couple of tools and an hour or so. First, open the door. Next you need a thin bladed Richard brand knife model #S-12 or a razor blade and a flat thin screw driver. The seal has been glued on and you need to find a place that you can slip the screw driver between the door and the seal. Jently pull as much of the seal away from the machine as you can. Once you find a glued piece slip the knife bewteen the seal and the machine to cut the glue. It is good glue so it will take some time to do this all of the way around the door opening. Once all of the glue has been cut, undo the plastic water spout clamp, reach inside of the machine and grab the seal by the top of the wash tub. Pull down and out at the same time and the seal will come out with a little effort but watch out for the tension spring. The spring has some tension and could come out rather quick so do not have your head by the door when doing this step. This concludes the removal and since you bought a new seal, all that is neccessary is to clean off all of the glue residue on the machine and the years of grime on the tub where the seal goes. Clean these areas very well and it will pay dividends later.
To install the new seal look on the wash tub at the top and bottom and there should be an arrow cast into the plastic in one of the locations. Line up the arrow on the rubber seal (search for it) with the one on the wash tub. Carefully instal the seal by having a finger in the seal groove and hooking the seal over and under the wash tub lip. Do not let the arrow slip to a new location as you are doing this. Once the seal is in place double check to make sure that the seal is properly installed. Now gently push the seal into the wash tub so that you have access to the outer lip of the wash tub where the tension spring goes. 2 people are required for the next step. One person will place and hold the spring in the groove and another person will stretch and feed the spring in both directions around the spring groove. Take your time and do not loose your cool with this step. If you need to use non pionted or sharp tools to assist, what ever works is fine. Once the spring is in place you need to reglue the door seal to the machine. I use black RTV silicone from your local auto parts store. Place some glue into the channel and pull the gasket out from inside the machine. Slip the seal over the lip all of the way around the door opening and remove any excess silicone. Let this cure over night before using the machine. That is the end and the door seal is replaced.
Posted on Jun 14, 2009
I have a Maytag Neptune front load washer that the tub is rubbing and is loud.
Could be the bearings . But it could also be the springs that center and hold tub in place. They weaken over time and it is not uncommon for a tub to be scraping because one of the springs is shot. When you replace one, you replace all at same time and eat your wheaties because they are hard to replace.
Sep 08, 2015 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune front load washer. When spinning it makes a loud noise. Could it be a bearing, what would be the price to fix it, and how hard is it to fix?
would most likely be rear bearing have to replace spindal with it/parts are costly and that is one of the tougher ones to do ..check you warrity may still have some on outer tub and inner basket...good luck
Feb 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer is extremely loud during the spin cycle and the detergent dispensing door is broke, How much would I be looking at out of pocket to get it fix or would it be cheaper to replace it...
The loud noise during the spin cycle is probally due to a bearing failure. Not sure how much it would cost to fix, but Maytag does not sell you the bearings but would sell you a new wash tub with the bearings installed for over $600! Add the labor costs which would be a lot since the machine needs to be taken apart to install a new tub, and you would be ahead of the game getting a new washer.
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
Im wondering how to get the bearings out of the drum?
you have to replace the back tub the bearing come built in the tub from the factory there is not any way just to replace just the bearings
Dec 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin Cycle
Yes its true the main support bearing is part of the outer tub and is factory set .Dry bearing will roar until it develops a leak and eventually starts a main pulley shake that will cut through the back of the outer tubs shell.The outer tub costs about $175.00(varies)the labor (please sit down)yes, is high enough for you to go out and find your self a 15 year old Maytag top load, re-build it,scrap the front load,and never see a repairman for the next 15 Years.No joke!                             I/m happy to help you with anything you need a answer to.............Sorry about your Maytag    :(
May 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
318 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
